I'm in process putting a pair of 312DIs together and cannot figure out how to get the small NKK switches on the sub PCB to line up with the front panel.I followed the instructions to shim the trim pot with the PCB board so it's lifted 1/16" up. As you can see in the photos attached, the pots seem to line up with the push button switches well and I think I've installed everything else correctly?Can't wait to hear it!Thank you
Hello,I did do the dry fit for the bourns pot as indicated in the first post. You mentioned that the bottom T pot shim directions were for the original solder lug version, are you suggesting that th new version I have should be soldered directly to the board, contrary to instructions on the PCB?
Very well, then it seems I've followed all the instructions correctly.I'll reheat some pads on the two pots to try to get them to move enough where all the components fit in their places.
If everything was done correctly then all should drop right in.So the mini toggles are not lining up? Are they tight and flat to the PCB? Nice and perpendicular? If so they should work no problem. There is some tolerance in the front panel holes to allow for some slight variations.
Correct, the mini toggles are off by 1/16"They are nice and tight and perpendicular to the PCB.
Started by jsteiger « 1 2 ... 48 49 » Preamplifiers
Started by jsteiger « 1 2 ... 7 8 » Preamplifiers
Started by jsteiger « 1 2 ... 22 23 » Filters/Equalizers
Started by jsteiger « 1 2 ... 52 53 » Preamplifiers
