taking notes from the thread...
#56
If it's not passing a mic signal and the DOA is known to be good, I would first check the PK2 relay to make sure that with no 1/4" jack inserted, pins 8 and 10 get coupled to the input transformers primaries. With a ground signal present at PK2's VC pin, the rear mic in will be couple to the 2622. When a 1/4' jack is inserted, the normal of the sleeve's contact is broken/opened which disconnects the ground from PK2's VC pin and switches the relay to the HiZ Plug-In as the source for the 2622's input.
If all of that is good, you will have to look at the output section. That is very short and sweet really but I would make sure it is not a solder joint on either the Mute or Polarity C&K switches.
#84
Well, like I said, there will probably be no magic bullet or smoking gun fix. When having trouble like this the "pot shot" approach to finding and fixing will most times never work. The only way to find and solve is systematic and methodical.
First, common sense things with the opamp. Is it a known good solidly built opamp? Who built it? Has it been verified good in another working device? Is the voltage switch set incorrectly for the opamp installed? I never test a freshly built preamp with a freshly built opamp. Too many variables.
From there, you will need to follow the schematic like a road map. You can follow signal from the input up to the opamp with no opamp installed. When in mic mode, does injected signal get to the first relay board? Does it get past it? Keep following all the way to the opamp.
When inserting a 1/4" jack, the rear relay will switch to DI mode. Follow the signal throughout the DI signal path as well.
This may seem like a frustrating time, but the rewards when you can systematically follow signal thru an entire device and find the culprit will be very rewarding. It will only make you a better builder as well.
#85
All of the things I am about to post can be deciphered by looking at, reading or following the schematic. This will become a necessity with the amount of kits you build if it's not already. Good troubleshooting skills will out weight good build skills any day. No matter how good a builder one may be, there will always come a time when you need to sort out an issue.
So, think it may be the t-pad? Easy. Let's bypass it and see what happens. By looking at the skiz we can see that the t-pad follows the 2503 output transformer. Desolder the Blue and Orange leads from the 2503. Temporarily solder them to an XLR or whatever means you need to monitor the output. Again from the skiz, Blue will be + and Orange will be -.
What are the results? Same issues? No sound and opamp heating up? I think we have ruled out the t-pad.
In a general studying of the 312 schematic, what would happen if the 2503 is bad? What if the primaries are shorted within the x-fo? Very rare but **** does happen. Again, in following the skiz, the DOA's output would be directly shorted to ground. Not good. Would probably cause a very fast over heating of the opamp. Maybe next you should desolder all the leads from the 2503 and measure DCR to see.
What is DCR between the following: (again, that damn schematic is the key!)
Red to brown?
Blue to green?
Yellow to orange?
Violet to gray?
Make sure your DMM is set to properly measure resistance under 100 ohms. Let us know what you find.
Last thing to mention, before I would have gotten to the above, I would have injected signal and followed it all the way thru the preamp. Where it stops would be the area to look. If the above holds true, things would be fine up to the DOA's input. Would be a great help to yourself if you could verify this. You will be thanking me for it one day down the road.
#113
You can beep for continuity between the A+ pin and the O+ pin (mic mode). Next would be the B+ pin to the O+ pin (DI mode). This info is on the skiz. There is just enough room where the 90 degree header comes out of the relay PCB to get your probe tips in. If this relay is not flipping with the plug going in/out of the DI jack, it's either a problem on the PK2 relay build or the control signal which can also be followed on the schematic. You must have DC applied to the main board for this to work.
#115
The relay in question that selects what input goes to the 2622 (mic or HiZ Plug-In) is PK2 that is situated more in the center of the PCB just behind the input transformer.
PK1 routes the DI input signal to the HiZ Plug-in or to the post 2622 position. You need to flip the mini toggle on the front to get this relay to active/deactivate. This can only happen with a plug in the DI jack.
#119
Well, I can't think of any reason why the mic in won't work then. If the relay PK2 board is fine, then the only difference between the output of that relay card from DI mode to mic mode, are a few inches of PCB traces and the gold fingers #8 and #10. Is this maybe an issue that lies between the card and the mic? Meaning rack or outside cabling?
#121
Well, many things are not making sense here. My suggestion is to pull both relay boards and make sure they are working right. I test them on a breadboard. 98% of all problems on a VP312DI build are related to those little relay boards.
If Pre 2622 DI mode works, mic mode should also work.
... gonna try swapping out the DOA and HiZ Plug-in PCB from the working VP312DI into the failed one... just to rule that out...
... otherwise Jeff repeatedly points toward incorrect diodes on the relay PCBs... So I'll have to double check those little suckers...
