dalmaproductions
Hi guys, I'm completely stuck on this, have tried almost everything. I'm using one of Igor's BA283 neve output boards. Transformers are Carnhill VTB9049 (LO1166) and Carnhill VTB9046 (31267). I have nothing connected to the board insert. Schematic:
http://i251.photobucket.com/albums/gg291/diy33609/ba283_mkup_sch.png
What I get at the out is a huge high end roll off. Its completely cut off around 600~700 Hz. If I inject a signal at J13-J14 after input transformer the problem manifests. If I inject a signal at the output transformer primary, I still get the problem, BUT, as soon as I disconnect the output transformers primaries from circuit, I can inject a signal to the output transformer and final output is perfect.
I've changed the bc184's, changed all electrolytic caps, reflowed all solder joints. Tested the output trafo in different circuit, works fine. Any Ideas?
