I guess you could just use wire to extend to the case mounted XLRs. I really like this idea! I think I might be in for 1-2 depending on price.zayance said:Nice idea 8) 8), easy enough....
But one thing tough, so the force applied when inserting the module will be taken by the XLR pins if racked right?
Wouldn't it be better to have 4 standoffs/screws options on PCB that would be screwed on back panel so to have a better stand
And so pressure applied won't do too much harm on XLR's?
I'm saying this without even having experienced them, but just wondering.
EDIT: The depth of the standoff's could be a bitch tough, anyway just thinking....
canidoit said:will adding a power supply be easy?
more likely you could make it work from a 3-rail +48,+24,-24VDC supply and the regulating down to +/-16V for the standard 15pin slot voltages can be done/jumpered on each adapter, if so required.plumsolly said:canidoit said:will adding a power supply be easy?
Looks like the PS is onboard - you just need a power transformer.
Ben
mylesgm said:Neat Idea. What is the module with the lundahl i/o? is that some sort of 500 pultec?
TomWaterman said:mylesgm said:Neat Idea. What is the module with the lundahl i/o? is that some sort of 500 pultec?
500 series Helios.
-T
canidoit said:I guess you could just use wire to extend to the case mounted XLRs. I really like this idea! I think I might be in for 1-2 depending on price.zayance said:Nice idea 8) 8), easy enough....
When do you think this will be available and will adding a power supply be easy?
Harpo said:more likely you could make it work from a 3-rail +48,+24,-24VDC supply and the regulating down to +/-16V for the standard 15pin slot voltages can be done/jumpered on each adapter, if so required.plumsolly said:canidoit said:will adding a power supply be easy?
Ben
Neat idea.
(Having all 7 potentials (5 voltage rails+0V+chassis) on doubled up connectors in a following revision might help for easier daisy chaining.)
zayance said:canidoit said:I guess you could just use wire to extend to the case mounted XLRs. I really like this idea! I think I might be in for 1-2 depending on price.zayance said:Nice idea 8) 8), easy enough....
yes true, but then the PCB and its socket is not holded securely, meaning that in a 51X rack, the front screw and the Card inserted gives a tight fit,
So if you rack it, you dn't want to have the Edac connector getting slowly out of its place so.....
Good catch! Maybe you could fashion some sort of L plates that allows you to screw or bolt it to the Blue API socket and case because I dont see any other room on the PCB to try and mount it somehow.
zayance said:Good catch! Maybe you could fashion some sort of L plates that allows you to screw or bolt it to the Blue API socket and case because I dont see any other room on the PCB to try and mount it somehow.
I Vote for screw holes on PCB 8), Please Igor :-\
