scott2000
Just an opinionated coonass...You bored? Or a better bot? Keeping an eye on you..
/Jakob E.
It's an interesting observation about the comp imo.
/Jakob E.
This is a grand gesture and huge gift to the community. Thank you for all the time spent.All files up, and everything out of our hands.
Hope someone has fun with it - we sure did!
On your diagrams you have one drawing where you have the 2 caps (6u8 & 0.47u) in different places.Sorry for troubling....
just for learning purpose and fun tried to simulate the CT net of the original Gssl compared to SoundSkulptor version in 500 format, since the last one has a smart configuration with only 2 caps..... believe to save space and the number of caps.
except the autoRelease position,where the slopes are very different maybe due to the dual element REL with different values, otherwise the curves are very close/similar...
What is your opinion?
thanx for your attention
best
I mean you have the 0.47u across the 750k resistor on the left diagram & across the 910k on the right hand diagram. The 910K is wrong it should be 91K. This is the Value on the original SSL diagram which is what all these compressors are derived from. You should consider that there are 2 time constants one stacked on top of the other. So you should get an initial quick release from the 0.47u across the 91K & then the tail end of the release is slower from the 6u8 across the 750k.are you meaning a different configuration and so different behavior?
what i get in mind is that when not in auto mode the 2 caps can be considered in series and so a value like 440nF....
in auto mode R12 & R13 are no more shorted to GND and so you can get a dual element Release....
also i did an error drawing it, i removed a connection at R6
edit: Altering R11 form 100k to over 1meg, the slopes are almost matched
Thanks for delving deeper into it... Now I have a clearer ideaI think what they are trying to achieve is the use of a single capacitor for all the single timing release values, but I am unclear about the way it is drawn up.
If I am understanding it correctly, and going by what Richi is saying, its done with a 910K static resistor, and switching various values into parallel to get the desired resistance per step.
The 910K switched in parallel with 100K for the auto-setting is just under 91K. The second pole of the switch does not to jump it to gnd on "auto", but it does so on the single-timing settings, where connection is made to ground directly from the resistor in parallel, seemingly to take out the 2nd timing stage.
In fact, at the beginning the first thing I did was reverse 910k with 750k.... because I understood that in standard mode the 2 caps could be considered one, but in doing so the curves move away.
Maybe the way I'm simulating rise and fall isn't correct, but I don't know any other methods to compare the 2 circuits, not so expert
Attached S.Skulptor's schematic part
Thanks for your support
Best
Thanks for this very useful info, I didn't know that.As far as I know, the correct configuration is 91K/470n followed by 750K/6.8uF, and the resistor values are stacked in reverse on the gyraf shem, although, actually correct on PCB.
