- Joined
- Jul 15, 2009
- Messages
- 2,307
D-U87 Build Thread
Let's get those Electron flowing.
All of the info: http://www.groupdiy.com/index.php?topic=49675.0
Picture Provided By Chunger
Mouser Cart including all options ( 60M and 68M included also 2 different PN for 2K2 resistance)
important note :The BOM already contained alternate part number for the 2.2K (delete whatever is not available at the moment and also there is both the 60M and the 68M listed in there for you to decide both will work fine
just delete from your order the one you wont take, the 68M is less expensive !
Most Recent BOM here :
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=1AD602D54E
Sound Sample Provided By Chunger and Exhaustive Build thread here http://www.groupdiy.com/index.php?topic=49389.60
Demonstrative Video Provided By Peterson Goodwyn at DIY Recording Equipment and Matthew Jenkins.
http://youtu.be/DtNH46jpwJo
Build Demonstration
http://www.vintagemicrophonepcbkit.com/Neumann%20U87%20Build.htm
Large PCB version in SYT-5 mic body
Taper Version in BM-600 Type mic Body
Microphone Body and accessories Available Here :http://www.groupdiy.com/index.php?topic=50015.0
The Original Version Contains Polystyrene Filter Cap, as this is an option not included in the BOM it may be ordered via the webstore
Styro Kit includes
1 X 10pf Styroflex/630V
1 X 220pf Styroflex/630V
2 X 470pf Styroflex/630V ,
1 X 560pf Styroflex/630V ,
Read This First : Assembly Instruction , Excel BOM and Tips For Assembly and Important Considerations Here: https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02019.xlsx
this will fit the Aurycle Micropone the MXL or any tapper standard Fet Mic Body
This is a Combo Set (2 Boards)
BOM , Layout ,Schem, ..... For this project,
Tutorial Document Thanks to UDO on how to wire the behringer B2 Pro switch board Here:
https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a0202b.pdf
How to make it in a behringer B2 thank to jasonallenh
https://www.dropbox.com/s/zm4eexpvpmhwab2/USING%20THE%20AMERICAN%20B2%20FOR%20DANYs%20U87.pdf?dl=0
B1 Reference Voltage and Schematic https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02050.pdf
B2 Reference Voltage and Schematic https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02062.pdf
Here a Fantastic FET Behavior Calculator ( Thanks To Matador)
http://www.musicalsparks.com/images/curve_tracer/jfet_bias.php
Important note :calibration resistor R11 is not Included in the Bom as it is specific for each FET.
use the potentiomter in the BOM to determine R11 Value.
Consider having those on hand the value of R11 Will be approximatively
Ranging from 7k to 12k
The new version of the Board include the Pot or resistor Package much easier
Dimension Here : https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02085.doc
Needed For this Project is a K87 Type Capsule With isolated backplate.
Best suited Capsule for this Project for this project: K87i by Peluso and can be found here :
http://www.pelusomicrophonelab.com/parts/Capsules.html
Best suited Capsule for this Project The RK-87 by Microphone Parts and can be found here :
http://microphone-parts.com/rk87-microphone-capsule/
http://microphone-parts.com/faq/
Best suited Capsule for this Project for this project: K87 by TSKGUY and can be found here :
http://www.groupdiy.com/index.php?topic=49859.0
capsule connection the Proper Way to make sure front is front and back is back:
Side A
Side B
See by your self Here Thanks To John Peluso : Frequency Response Test from John Peluso (K87-PK87i) : https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a020fd
Here are the best suited transformers for this project :
New T13 From Tab-Funkenwerk The T13 was designed specially for the u87 circuit by Tab-FunkenWerk
http://www.tab-funkenwerk.com/id133.html
CM2480 from Cinemag http://cinemag.biz/mic_output/mic_output.html
New Peluso T87 Specialy designed for this application
More Info here : http://www.groupdiy.com/index.php?topic=47350.300
How To measure FET Idss By Matador https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02141.jpg
FET Biasing Method By ZapNSpark : https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02152.pdf
Reference Version 16 Schematic: https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02163.jpg
Manual and Version 21 Schemo : https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02175.pdf
Tuning Hint : http://www.groupdiy.com/index.php?topic=47350.340
To Bias Fet, make sure you install R6 backward in reference to the silk screen like this:
this is Valid for Large Version and Taper Version do not do this for the Blue PCB version
Tuning Thread : http://repforums.prosoundweb.com/index.php/topic,11630.0.html
Precious Info on how to use a scope to Bias a Fet (Thanks To Matador) http://www.groupdiy.com/index.php?topic=46109.40
Here is a software based oscilloscope for those interested :
https://cdn.groupbuilder.com/groupdiy/u/39511/58d0281993732.exe
Here a List of suggested Mic Bodies ( Thanks To ChuckD )
All Switches
Behringer B-2 Pro
MXL 2010
Filter and Pad Only
Aurycle A460
MCA SP1
CAD GXL2400
Carvin CM87S
No switches:
Gauge ECM 87
Nady SCM 900
Cheers Dan,
Build Demonstration
Styro Kit includes
Side A
Side B
All Switches
Behringer B-2 Pro
MXL 2010
Filter and Pad Only
Aurycle A460
MCA SP1
CAD GXL2400
Carvin CM87S
No switches:
Gauge ECM 87
Nady SCM 900
Cheers Dan,
