mjrippe
I have searched all over the web for a replacement pot for the "Air" band of a Nightpro EQ3-D.  The original pot is a Bourns "91C1D-D20-T23L" which is a 500k reverse audio taper pot with a 1/4" bushing and an 1/8" x 5/8" shaft.  I contacted Bourns and none of their distributors have any stock.  The only Google hit was a company in England that sells by the 1000's.  Nothing at Digi-Key, Mouser, or Newark.  In fact nobody has anything compatible in stock.
I don't care if it's not PC mount and I am ok with drilling out the holes for a larger bushing and shaft, but the body of the pot still has to be no more than 5/8".  Also the shaft length is important (lol).  Any suggestions or sources would be appreciated.
Mike
gyraf
find a place that officially services that product?
Brian Roth
Try:
http://potentiometers.com/
it might cost you $50 or $100 for a single, though.....
Bri
Brian Roth Technical Services
Salina Kansas, home of the best vinyl on the planet!
http://www.BrianRoth.com
recordingservicesandsupply.com/
www.qualityrecordpressings.com/
store.acousticsounds.com
mjrippe
Gyraf - NTI or Nightpro went under a long time ago.  No authorized service centers exist.
Brian - Thanks, that's quite a site!
gyraf
Ah - I see.
Maybe try asking the good people at audiomaintenance.com - they can often dig up obscure stuff, and have a good selection of sfernice post..?
Jakob E.
mjrippe
Jakob - Thanks, I will do that!  In the mean time I ordered some pots that *might* fit from an ebay seller in the UK.  Will let everyone know how it goes.
mjrippe
So I received the pots from ebay seller "mallinson-electrical".  They were very professional and shipped them very quickly.  They are Alps 500K reverse log and they JUST fit into the EQ3-D.  The pin spacing was different so I had to install the pot with the pins up and wires running to the pcb pads.  Once that was done, I tested the EQ and all was well!  The pot shaft was a bit shorter but I was able to find a knob that grabbed it OK (from an old Tascam 4 track  :P).
Thanks for all the helpful suggestions, I will certainly use those links in the future.
Last post May 28, 2005, 08:20:57 PM
by [email protected]
Last post November 10, 2006, 01:17:28 PM
by StephenGiles
Last post January 17, 2012, 10:58:48 AM
by regularjohn
Last post August 25, 2009, 10:02:47 AM
by kato
