Vintage Tube & Vintage FET Microphone PCB Kit For DIY & New D7 Custom Capsule
poctop
White Market Member
Authentic Vintage Circuit Microphone PCB : D-U67 Tube , D-U87 , D-U47FET, D-M49,  D-M269 D-Ela M251 D-47 DEF47 D-12 and New D7  (M7)  Custom Microphone Capsule
https://www.instagram.com/poctop/
More Info Here
https://groupdiy.com/index.php?topic=49675.0
Mechanical Mic  kits are back in stock, :)
Matt Head Style is Now Available Limited Qty initial run
D47 Mechanical Kit
For the First Time U48 is also available in limited Qty initial run
U48 Mechanical Kit
Includes
-Wooden Box
-M23 German Binder Mic Side
-Capsule Holder
- Tube Socket of your Choice ( Dual , Noval, Steel Can) and Mounting Hardware
- PCB or your choice  for different Transformer option and a Total of 3 different Circuit ( ef8XX-EF14, Dual 6028, EF12)
-Custom Heatsink on Request for Dropping resistor for original circuit or Dual 6028 circuit
- Plain Metal Deck supplied on request.
- Layout Diagrams of your choice.
-799USD Per Kit
DOC
Build Info and layouts
Dropping Resistor Installation  Note : Washer Below Heatsink.
M23 Binder Mic Side Insert Removal
https://www.dropbox.com/s/h9wmp28vwu0f3l8/Binder%20M23%20Insert%20Removal.zip?dl=0
D7 Custom Capsule
Vintage Microphone Build
Order a PCB  http://www.vintagemicrophonepcbkit.com
All PCB Dimension :https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a02446
All Mic Body and Accesories Available Here: http://www.groupdiy.com/index.php?topic=50015.0
[size=13pt]The Build Thread
D-U67                http://www.groupdiy.com/index.php?topic=50021.0
D-U87                http://www.groupdiy.com/index.php?topic=48030.0
D-U47FET          http://www.groupdiy.com/index.php?topic=49758.0
D-M49 B,C          http://www.groupdiy.com/index.php?topic=50834.0
D-M49 B,C round http://www.groupdiy.com/index.php?topic=51862.0
D-M269B              http://www.groupdiy.com/index.php?topic=50834.0
D-M269C            http://www.groupdiy.com/index.php?topic=51714.0
D-Ela M251        http://groupdiy.com/index.php?topic=55010.0
D-EF47    http://groupdiy.com/index.php?topic=56878.0
From Thoughts to Metal to Soundz,
D7 Custom Microphone capsule
http://www.vintagemicrophonepcbkit.com/Caspsule.html
250USD  Per Capsule (D7 Mount not included) Shipping and PP fees Extra
D7 is an M7 Type Capsule  built with Mylar Gold Sputtered 6um
D7 Mount is 58mm in Height 40USD
D7 Mount 50mm is also Available for GT2B style Headbasket 40USD with capsule
PM me if you have any questions
Best,  :)
Dan,
D7 Microphone Capsule
D7 Mount
The D-U67 Tube Mic
D-U67MKBV12 Set (TransFormer Not Included )
( includes : PSU PCB, Tube Socket PCB , Mic PCB , Switch Board PCB)
58d1402a024e8
BV12 from Ioaudio Available Here: http://www.groupdiy.com/index.php?topic=35667.0
58d1402a024f7
D-U67 AMIT67 or External Transformer Set (TransFormer Not Included )
( Includes : PSU PCB, Tube Socket PCB , AMI T67 Adapt Board, Mic PCB , Switch Board PCB)
58d1402a02527
AMI T67 Transformer Available here: http://www.tab-funkenwerk.com/id114.html
58d1402a02537
New D-U87 PCB for Large U67-U87 Mic Body.
Picture Provided By Chunger  :)
D-U87 PCB Set Standard Taper
The D-U87 Mic
58d1402a025bd
Taper Version in BM-600 Type mic Body
New  D-U47FET
DU-47FET PCB set
The D-U47FET  Mic
Fits also ALctron GT-2B Style mic body.
New D-M49 (b-c) combo Tube microphone PCB set
Square Set 44mm * 48mm + AMI T49 Support PCB
Round 60mm Diameter Version
Mic Build in Gt-2B style microphone.
D-M49 Tube Mic
Thanks guys, i tought i'd share the some pictures i gathered of  of those.
D-U87 FET Microphone
Photo by Chunger  :)
Photo By Chunger  :)
D-U47FET Microphone
Photo By Ben  :)
D-U47FET Microphone
Photo By Ben  :)
D-U47FET Microphone
Photo By Ben  :)
D-M49b Tube Microphone
Photo By Ben  :)
Photo By Ben  :)
D-M49c Tube Microphone
Photo By Ben  :)
D-M269b Tube Microphone
Photo By Ben  :)
Photo By Ben  :)
D-M269c Tube Microphone
Photo By Ben  :)
Photo By Ben  :)
Photo By Ben  :)
D-U67 Tube Microphone
Photo By Ben  :)
Photo By Ben  :)
Photo By Ben  :)
Photo By Ben  :)
Photo By Ben  :)
D-M49c Circuit
Photo By Ben  :)
PsU 2469 Passive For D-M49 and D-M269
Photo By Ben  :)
D-U67 PSu
Photo By Ben  :)
Ela M 251
D-EF47
PCBS
Mic
D-M49
D-47FET    3 Railing system (AMI-IOaudio) microphone body type.
i am working with Oliver to have the tube Cut , i am expecting a prototype soon, so will see,
The Pricing as Follow:
Note : 3% Paypal Fees are automatically added to your Total before Shipping.
D-U67 PCB Kit Exterrnal Transformer  55$CAD +13$CAD Shipping&Handling.
( includes : PSU PCB, Tube Socket PCB , AMI T67 Adapt Board, Mic PCB , Switch Board PCB)
D-U67 PCB Kit Max IOaudio BV12  55$CAD +13$CAD Shipping&Handling.
D-U87 PCB for Large U67-U87 Mic Body  25$CAD +13$CAD Shipping&Handling.
D-U87 PCB Set Standard Taper  20$CAD +13$CAD Shipping&Handling.
D-U47FET PCB Set   25$CAD +13$CAD Shipping&Handling.
D-M49 (b-c) PCB Set Round or Square Version   50$CAD +13$CAD Shipping&Handling.
D-M269c  PCB set    55$CAD +13$CAD Shipping&Handling.
I'd like to take 2 U67 and 2 large body U87 kits, if it's possible to pay after 10th sept?
Hi!
Nice job!
I'm in for 4 sets but i'll wait for the second batch.
Is the BOM for 110v only or international? I think i saw a 110v primary transformer in there.
Emil
Hi
I'd like one Ioaudio  BV12 PCB set
And one larger style U87 kit please.
Neil
On your old U87 boards mic the figure 8 setting is not the default all open setting. Did you fix that with the new boards to work with this new body?
This cannot be adressed in the circuit it has to be that Way like the original Neumann are , the issue is with the print on the mic Body CHuckD and Chunger have been notified and it will be corrected on the mic body,
Hope this helps, :)
Best ,
Dan,
