kml23956
It does help...thanks.
Winetree said:Looking at the two options,
Looks like both kits contain the same PSBs with the AMI kit
containing an extra PSB (the AMI T67 Adapt Board)
which allows the use of other mic transformers mounted in the Power Supply case.
Is this correct? Can you still use the internal BV12 with the AMI Kit?
I want two kits just not sure which one.
braeden said:I'd like to build two of these but not sure how much they're going to cost all up... I'm guessing everything is included in this kit except the microphone body? where are they sold?
Studio Mollan said:Hi!
Nice job!
I'm in for 4 sets but i'll wait for the second batch.
Is the BOM for 110v only or international? I think i saw a 110v primary transformer in there.
Emil
wave said:Studio Mollan said:Hi!
Nice job!
Emil
Emil,
The 230V Triad is 115/230 but the 20V Hammond in the BOM is only 115V
Here is an alternative for your mains but there is a lead time
http://www.mouser.com/ProductDetail/Hammond-Manufacturing/186B20/?qs=sGAEpiMZZMvwUzoUXIIvyQPvPmwnNFGyR%2fQB%252b1BzrOY%3d
It looks like the 115V Pri 20V Sec Hammond in the BOM is looking non stocked as well
Dave
Winetree said:Poctop,
Edit : "Actually did not have a preference either so I built one version of each"
Could you describe the difference in sound between the two versions?
Still on the fence
canidoit said:How about the power supply for this?
Is there a kit for that?
0dbfs said:Hi Dany,
I would like to feel/pre-order the following (declaring my intent to order):
2x U67 ioaudio trafo PCB kits. That is PCB's for ending up with two DU67 mic's and related PSU's.
Correct
5x Old style U87 (original smaller taper boads) OK,
This is a feeler right? Not official order? it is sort of in between not order nor feeler just firm intent so i can gauge the number of PcB as the first Run will be somehow limited, and i wold like to let know Folks if i am out , but no yet
Let us know when to place the order.
Will do ,
thanks Jb, Thx!
-jb
Jim50hertz said:As to components, it's source your own time.
Complete Bom has been posted on page 1
the only difference for international 230V, is the 20VAC traffo, and the fuse 0.1A instead of 0.2A everything the same ,
The 'kits' refered to are sets of pcbs.
Correct
