Hi
I'm in the middle of DIY VU Meter project, and i'm adding Peak LED Indicator into the circuit
the idea is, i'm try to model the peak indicator behaviour of my RME 9632 TotalMix control panel mixer, so my analog VU meter peak led will blink in sync with my soundcard control panel peak led
my method for finding treshold for soundcard control panel peak led :
- using 1 khz 0dBFS sine test tone vst plugin in Cubase 5
- adding another vst plugin to boost level above 0dBFS, i'm using sonalksis FreeG
- i found out my soundcard control panel mixer peak led start blinking with signal 0,7db above 0dBFS
- after that i'm calibrating my vu peak lead to match the soundcard control panel peak led
ps: my soundcard manual dont state at what level in dBu/dBV the peak led is blinking
my question is :
- is the 1khz sine test tone, "boost gain till it peak" is the easiest and valid method for calibrating peak led without using exact dBu/dBV number?
- at 1khz i manage to match my vu peak led treshold to match the soundcard peak led, but why at low freq (60-200hz) is totally different?, while the soundcard peak led is blinking, my vu peak led not blinking
here i attach my peak led schematic
thanks
my question is :
thanks
