Re: Neumann U67 Clone : D-U67 Tube Microphone Build Thread.
« Reply #1600 on: December 03, 2020, 04:51:09 PM »
Mouser https://www.mouser.com/ProductDetail/502-QG7M is more expensive, but quick.
« Reply #1601 on: December 07, 2020, 11:33:49 PM »
My D-67 is alive!  Powered right on the first time.  Used AMI T-67 and have a nice Amperex EF86.  Sounds great even with the old Chinese K67 capsule.  My Heiserman HK67 due around xmas -- I hope Santa delivers it soon!
Thanks to Dan and everyone participating in this thread.  It was a complicated build, but I had a lot of fun doing it.  Of course I just want to make another now...
« Reply #1602 on: December 19, 2020, 11:00:11 AM »
That looks pretty awesome! I am itching to get mine together.
I have everything needed to get this project done, but I am still waiting on the pcb's. How long does shipping the pcb usually take? I made my order over two weeks ago, but haven't seen anything yet. I emailed Dan, but he must be on Christmas vacation.
« Reply #1603 on: December 19, 2020, 11:14:15 AM »
Two or three weeks is usual, but this is the holiday season, so all mail is taking longer.  Dan is in Canada, too, so if you are in the US that adds more time.
« Reply #1604 on: December 29, 2020, 11:40:17 AM »
I am trying to be patient, but it has been a month since I sent my order in for the PCB. I have over $600 worth of parts sitting here waiting (that's a lot for me) and I can't get any response from Dany. I sent an email two weeks ago inquiring about delivery time, and also sent an email 2 days ago both have gone unanswered.
Edit: I just received an email from Dany in response to this post. All is well and he has assured me that everything is on its way. That's all I wanted. Thanks
« Last Edit: December 29, 2020, 01:31:01 PM by Naterbater »
Delta Sigma
« Reply #1605 on: December 29, 2020, 02:29:57 PM »
Has anyone tried fitting one of Dany's PCBs in a TLM67? i would want to install Moby's BV.12 so I'd need to know if the AMI PCB would fit.
I don't have access to a TLM67. I'm considering buying one then coverting it down the road.
Neil Fitzpatrick
Murdock
« Reply #1606 on: December 29, 2020, 03:07:29 PM »
I doubt that they fit as the SYT-5 body is quite different in size. But I'm not sure.
I have made PCB's almost identical to the orignal U67. I used them to use a U87 test head I acquired some time ago for cheap and built a U67 around the head... Later I used the same PCB to convert a TLM67.
As Mobys transformers  are identical to the vintage ones they fit my PCB's. I also used them in my builds.
Here are some pictures:
https://drive.google.com/drive/folders/1i2P9C5U1xjLcMZqWRc-dmJocUzqyZ-l6?usp=sharing
I can send you some pictures of the finished units if you're interested.
deveng
« Reply #1607 on: December 30, 2020, 02:24:47 PM »
doqmemory,
What body did you end up using?
« Reply #1608 on: January 01, 2021, 11:57:49 AM »
doqmemory,
I used Chunger's Budget-YT5 that I previously had Dan's D-87 in.  Now I have to find a home for the D-87 blue PCB.  I think it will fit in a Behringer B2-Pro body, if I shave off the sides and drill new screw mount holes.
If the nice SYT-5 bodies get back in stock, I will probably make another D-67, and/or a D-269c (point-to-point, since Dan no longer has the PCBs in stock).
Ricardus
« Reply #1609 on: January 01, 2021, 11:45:34 PM »
Is still in business and shipping and stuff. I'll be needing a U47 body, soon.
Audio mastering for hire..
useme2305
« Reply #1610 on: January 02, 2021, 08:04:28 AM »
the 67 pcb kit is up for order on his site though as far as i can see.
Delta Sigma
« Reply #1611 on: January 02, 2021, 06:43:12 PM »
I think he meant the M-269.
Neil Fitzpatrick
« Reply #1612 on: January 05, 2021, 09:54:46 PM »
My PCB's showed up yesterday!
Just thought I'd share my build since it is a little unique. I am mounting my psu in a 1u rack enclosure because I had it. It looks like it will fit nicely in about half of the space available. In the future I am thinking that I will build a pre and stick it in the other half of the case. I just finished mounting all hardware and I was going to paint it, but first I think I will drill a honeycomb pattern in the top to vent some heat.
For those who are looking for a mic body, the cascade vx20 is not a great option. On the rails I had to modify the width and extend them about an inch, but the real problem is that the body tube diameter is too small. I took it to a machinist today and we came up with a plan that should only cost about $50. Hopefully it works out.
I was going to post a picture, but the attachment feature seems to be out of order.
« Reply #1613 on: January 06, 2021, 06:48:36 PM »
Yes, the M-269 PCB set is out of stock.  If we can get at least 50 commits, Dan might get another batch made.
« Reply #1614 on: January 10, 2021, 11:27:41 AM »
Here are some pics of my finished psu.
« Reply #1615 on: January 23, 2021, 03:50:55 AM »
Got the body back from the machinist this afternoon and spent some time with the dremel cutting slots for the switches. Upon first startup with the body installed there was a major hum. I thought for sure that I had done something wrong, but it turned out to be a bad mic cable from the psu to the preamp. Changed it out and now it's dead quiet. I tried an amperex bugle boy and a mullard (both nos) and they were both nice and quiet and neither were microphonic! Right now I have the amperex burning in, but it already sounds spectacular! I'll post a few pics of the mic in case anyone is interested in modding a similar body. In the end it was not too much work to make it fit. I had to modify the rails and have a machinist do a little work on the lathe. He only charged me $35.
« Reply #1616 on: January 26, 2021, 07:10:37 PM »
 I ended up needing to lower the value of the 56k resistor in order to reach 210vdc. all I had readily available was a 39.2k Dale 1/8 watt. It worked great , but I was wondering if 1/8w is enough? The recommendations I've seen call for 1/4w.
« Reply #1617 on: January 31, 2021, 10:24:43 PM »
Put some waterslide decals on it tonight. They look OK. The inspiration for the name is a combination of the name of my studio, Rockharvester, and the name of the kit, D-67.
Last post March 07, 2021, 03:49:47 PM
by Purplenoise
Last post November 20, 2020, 10:34:42 AM
by doqmemory
Last post June 10, 2013, 05:16:32 PM
by radardoug
Last post December 18, 2018, 05:29:16 AM
by hugo
