Can you summarize your troubleshooting? Tube: burn-in and swapping, hiss with capsule and without, etc. It makes it easier for someone quickly browsing the forums to help.
Did you try a new tube? Can you grab one out of a guitar amp? Even if the noise increases with a 12AY7 from a guitar amp it may help you decide the tube is the issue.
When does your 6072a arrive? Is it a Five Star from a reputable source?
All symptoms happened with capsule in. Tried 3 different tubes. 1 (6072) crackled like an egg frying, I know that's bad. 2nd (12AY7) just had the hiss and low vol ground hum, as did the 2nd (the NOS 6072 which arrived), I'm thinking the latter 2 tubes are ok. Disconnected the capsule. Used 2 47pf's to connect the diaphram's front and back capsule. Then used an 80pf to just connect the front capsule, and same reaction from both of the latter tubes. Without the entire mic body assembled, large ground hum. With body screwed in proper, the hiss (it does sound like the pre was turned up too loud. That much hiss should be POPPING volume, but it isn't). I believe the 2 tubes to be sound.
So now the mic has the 80pf connected, Diaphram disconnected.
