Okay, so far... when it comes to stuff I've built, I have found that once I switched to the superior HL-95 body, the UTM 5087 with the Fuchs and Arienne k87 v1 is the best match for the u87ai on me. Now that I've had time to listen to a number of different transformers in the ORS 87, just not the UTM, I'm probably calling the GZT-87 my next favorite choice as it also sounds close in my Holy Fuchs mic, but the UTM is closer.
I just want to make a remark:
In U87i with a polarized voltage of the capsule of maximum 46v, the signal that will pass through the transformer is significantly lower than in the case of U87ai with a polarized voltage of the capsule of 60v.
With a small signal, the transformers (I would say the tubes too) are more neutral, but when they are attacked with a larger signal, they reveal their true character, the saturation, the harmonics stand out. Depending on the size of the magnetic core, the type of lamination, the material of the core alloy, possible thermo-chemical treatments, the quality of the winding wire, inductances, DC resistivity, parasitic capacities, resonances, etc.
So I noticed the bigger differences in transformers in U87ai, in general in circuits with high gain.
As a joke, I recall an extreme combination tested a few years ago:
Rode NT1a capsule that produces a large signal (stock is polarized at about 70v, I gave it 85..90v)
Jfet with small Idss, so higher circuit amplification
Audio power supply over 29v recommended, 31..32v
jFet Bias for maximum output.
Transformer: the little Neutrik10/3 !!!
The result: very high output signal, saturation, high harmonics.
But on spoken voice, moderate level, I was delighted. I had an amazing DJ voice and a surprising compression.
Radio-ready voice!!
