Let's start with an original document from Vacuumschmelze, one of the Neumann supplier.
http://www.filedropper.com/1957vacmateriauxmagntiquesdoux20111021
Fra
Fra
bubbi said:Does anyone happen to have a copy of the DIN 41301 ?
According to the Neumann winding sheet floating around here that standard should contain some info on the material.
Sorry I don't understand what document you have to pay?Unfortunately I have only found them paying, no free download
Moby said:Hi guys, nice Topic.Sorry I don't understand what document you have to pay?Unfortunately I have only found them paying, no free download
i can't see the recipe just the sheet with commercial info. Which material you think is right? Mag 7904?BraFra said:Finally the correct recipe from the other supplier of Neumann, Krupp, as you can see in this document this alloy is under DIN E3 41301 and so is the correct one as indicated in the Neumann BV-08 specs file. In the document, the correct composition and also the correct heat annealing treatment...no secret at all
http://www.filedropper.com/magnifer7904e
Fra
Moby said:i can't see the recipe just the sheet with commercial info. Which material you think is right? Mag 7904?BraFra said:Finally the correct recipe from the other supplier of Neumann, Krupp, as you can see in this document this alloy is under DIN E3 41301 and so is the correct one as indicated in the Neumann BV-08 specs file. In the document, the correct composition and also the correct heat annealing treatment...no secret at all
Fra
Pip said:Hi:
I'm glad to see this started as its own thread. But the filedropper documents are not loading so hard to discuss or follow.
BTW, chemistry differs from VACIn the document is clearly write the recipe Ni 80%, Mo 4.9%, Mn 0.5%, Si 0.3%, C 0.02% and Fe to balance and it respects also what is write in the Vacuumschmelze document
Moby said:BTW, chemistry differs from VACIn the document is clearly write the recipe Ni 80%, Mo 4.9%, Mn 0.5%, Si 0.3%, C 0.02% and Fe to balance and it respects also what is write in the Vacuumschmelze document
I'm talking about this. That's not a recipe , thats overall info and it's believe or not used as start point for BV8's lam's chem. Original is custom made and my measuring shows that. Again, it's possible to replace original alloy with modern mixtures and tweak it to same permeability with proper final treatment but it will be still just similar. I have no problem with that, but if we are talking about exact alloy used in original BV8 then we are wrong. So what' the point of this thread? To make something or just to feed users curiosity. If it's curiosity , than yes, you are right. that's itNi 72-80% some parts of Mo, Mn, Si and Cr and Fe to balance
Of course, i'm talking about that . But I start to talk about that because I wanted to know is the new BV8 made from Austrian guy original or not. If yes why to search for more?poctop said:I like this for sure , a Laser-ARC ICP-Mass-spectrometer and xrf could resolve the questions and myths,
I have acces to ICP Mass spec but ... I need a laser
Dan,
