I'm building this PSU to use with two channels of A_P*I 3_1_2:
PSU pdf
I took ideas from various projects around (G9, etc) and would like to know if it's ok or needs adjustments. I simply used 7818 and 7918 for opamp supply and derived one of the secondaries to build the phantom part, using a voltage doubler.
I also need a +24 supply for some relays, is it good to put a LM7824 in parallel after the diode bridge? I've read in some other thread that it's not a good thing to power relays from the same supply...
Many thanks for any help,
Frank
PSU pdf
Frank
