Cable for G7
stefan
Sweden
Wich Mogami cable is the one to use for G7? is it the 6-conductor+Sheild? Shouldn´t It be possible to run the heater 0V trough the same cable as the ground and then split it in the PSU if one wanted a ground lift on the Audio signal?
