BBC AM6/17 schemo pics for someone to host
« on: February 10, 2005, 09:48:02 PM »
I have from a friend pics of the BBC AM6/17 comp schemos. Who can host them?
« Reply #1 on: February 10, 2005, 10:04:33 PM »
fire 'em over
« Reply #2 on: February 10, 2005, 10:30:00 PM »
Done, duh I just saw your email.
CJ
« Reply #4 on: February 10, 2005, 11:35:39 PM »
Yukka! Chips.  :sad:
I'm out.
 :razz:
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
gyraf
« Reply #5 on: February 11, 2005, 03:46:49 AM »
Here's a .PDF with the above - in one file, and somewhat reduced in size:
http://groupdiy.twin-x.com/albums/userpics/10004/BBC_Am6-17_Limiter.pdf
Jakob E.
« Reply #6 on: February 11, 2005, 11:40:36 AM »
I still have the AM19 preamp specs if anybody still wants them (or has somebody already loaded them up to the web?)
strangeandbouncy
« Reply #7 on: February 11, 2005, 05:37:43 PM »
Tubemonkey/Miko,
    Thank you so much! My copies have disappeared somewhere in the miasmus of having been flooded out . . . .
    One of my Neve 6/17's is a bit temperamental, and I needed a schemo . . . . .
    Serendipity or What?
          Thanks Again,
           Andy P
. . . . RUH ROH . . . . .
strangeandbouncy
« Reply #8 on: February 11, 2005, 06:08:31 PM »
CJ,
   Chips, yeah, but these baby's are Hella Cool! They really Suck, and I don;t mean that in a derogatory manner! They also stereo match better than pretty much anything, except an SSL. Try phase reversing one side and re-combining the output of most so-called Stereo comp/Lims!
     Wish I'd bought more of these when they were still cheep! i too turned up my nose at them because they were full of chips . . . .
        Each to his own, eh? . . . . .
              Andy P
CJ
« Reply #9 on: February 11, 2005, 06:13:18 PM »
OK, I'm back on the chip boat!
 :thumb:
strangeandbouncy
« Reply #10 on: February 11, 2005, 06:15:02 PM »
That was way too easy!
« Reply #11 on: February 11, 2005, 06:19:02 PM »
It's about time I nailed my pair into a box.
http://www.lazpro.com
I reserve the right to not sell to idiots
strangeandbouncy
« Reply #12 on: February 11, 2005, 06:50:45 PM »
Peter,
    If you to are allergic to chips, Maybe I could look after them For you? :green:  :green:  :green:  :thumb:
        Andy P
q2audio
6/17
« Reply #13 on: March 24, 2006, 04:09:34 PM »
I have a set of these on my bench right now - I've found some things on the PCB that are not consistent with the schematic. For instance, the anode of 1D9 connects directly to 1IC6 pin 13 (not to 1R67 (10K) as shown). Also, there is a handwritten note that PCB pins 34 and 35 (part of ratio switch feeding 1IC6a) are reversed. I traced it out - what should go where per the schematic, and this is in fact the case. When I reverse wiring to 34 &35, the zero of the meter changes slightly with each setting of the ratio switch... leading to my question: is this normal? Does anyone have a correct unit? Before I did this to the "working" unit, the zero shifted quite a bit less if at all.
Any ideas or comments?
I agree, regardless of the chips, these units are WAY cool...
Re: BBC AM6/17 schemo pics for someone to host
« Reply #14 on: October 13, 2016, 06:35:24 PM »
None of the links work any longer. I would love a copy or a a working link to download this info. I have a few of the Calrec versions to rack up, test and calibrate.
Last post July 05, 2004, 07:47:21 AM
by Kev
Last post May 04, 2006, 07:14:42 AM
by Tekay
Last post October 02, 2006, 02:51:47 PM
by datape
Last post January 14, 2021, 07:25:57 AM
by snigglepit
