bernbrue
Re: [BUILD] STA LEVEL PCB OFFICIAL BUILD & HELP THREAD
« Reply #200 on: March 28, 2016, 12:21:06 PM »
Updated 2nd post with wiring guide made by Monoklang! Thanks a lot, John.
Ethan, thank you very much for fixing the page 11 issue! Works great now!
Matt55
« Reply #201 on: March 28, 2016, 04:18:01 PM »
I would like to add a huge thanks for the wiring diagram, will help me out no end when I come to build my one. Im still gathering parts and waiting for the cases from Steve but im excited already!!! Thanks, Matt
core13
« Reply #202 on: March 28, 2016, 05:05:41 PM »
Hi bern do you think it can be interesting to put carbon resistor?
bernbrue
« Reply #203 on: March 29, 2016, 04:19:43 AM »
Honestly I doubt that carbon resistors would improve anything. For me they do the same as all other resistors, they resist  :)
Edit:  found a good article about this topic
http://www.aikenamps.com/index.php/resistor-types-does-it-matter
Bernd
« Last Edit: March 29, 2016, 06:18:53 AM by bernbrue »
core13
« Reply #204 on: March 29, 2016, 11:06:09 AM »
thanks for the link it's interesting
I will try to learn more about that
it's sure if it just bring some noise it's not interesting
Krcwell
« Reply #205 on: April 02, 2016, 03:19:35 PM »
Hi Bernd, I'm shopping around for an input transformer. It looks like this is the Jensen you are using, JT-6610k-B? How do you have it wired?
http://www.jensen-transformers.com/wp-content/uploads/2014/08/jt-6610k-b1.pdf
bernbrue
« Reply #206 on: April 02, 2016, 03:25:38 PM »
Like in the test circuit shown in the data sheet, just the other way round. No zobel network.
Bernd
zayance
« Reply #207 on: April 02, 2016, 11:10:04 PM »
oh wow, Thanks for your work on the wiring guide Monoklang! I've missed that one.
T.
« Reply #208 on: April 03, 2016, 01:13:00 AM »
Well, since this is my first tube project I wanted to understand the connections and wirings before I actually do them.
But please check so I don't have done any mistakes.
A question: is it wise to have more then one star ground connected to the chassis?
I read somewhere that the IEC ground can be close to the IEC/power transformer. But to avoid hum, put another chassis ground near the input tx. ??
John
bernbrue
« Reply #209 on: April 03, 2016, 03:02:09 AM »
No, only one star ground near IEC.
Bernd
« Reply #210 on: April 03, 2016, 08:38:25 AM »
Ok. Good.
I saw that I missed to connect the relay board to star ground I the wiring guide.
John
« Reply #211 on: April 13, 2016, 08:19:57 PM »
BOM says output pot should be 1k lin but the mouser part number came back  50k. can i use it or should i order a new one? thanks
bernbrue
« Reply #212 on: April 14, 2016, 12:52:33 AM »
We definitely need a 1 K pot here.
Bernd
kosi
« Reply #213 on: April 14, 2016, 03:45:24 AM »
while you're at it: there's also the switch missing for the relay board
Ok. Good.
John
« Reply #214 on: April 26, 2016, 01:26:03 PM »
does anyone know how to hook up the don audio trafo in 120v? thanks.
bernbrue
« Reply #215 on: April 26, 2016, 02:45:50 PM »
Here is a diagram that should give you an idea.
http://electro-dan.co.uk/electronics/wiring.gif
Bernd
« Reply #216 on: April 26, 2016, 09:24:14 PM »
thanks.. sorry for all the stupid questions but none of the colors in the diagram correlate to the trafo.  it has orange,  purple,  white, yellow, and yellow with green stripes.  the diagram is brown,  white,  black,  and pink. thanks agin.
Le Roux
« Reply #217 on: May 10, 2016, 07:00:03 AM »
Hi
I cannot seem to find this info.
I see jumpers being used on the input pad and one other on the main pcb.
I plan on using Sowter in & out, do I need to jump these positions?
And am I ok with using the resistor values on pcb?
Neil
bernbrue
« Reply #218 on: May 10, 2016, 07:05:39 AM »
Build it stock with resistors for input and output pad. When using sowter tx you'll need the input pad anyway. As far as I remember you don't need any jumper on the mainboard (read first post), but there need to be jumpers on the control board.
Bernd
bernbrue
« Reply #219 on: May 22, 2016, 03:51:50 PM »
Zayance ordered a new batch of pcbs.
http://groupdiy.com/index.php?topic=53011.0
Best
Bernd
