Hello folks, I hope this message will find each of you in great shape ;-)
I need your lights please, my B channel won't pass audio when engaged...
Channel A seems working properly. Unit built with sowter xfmrs, 1,2mA meters (but I'm looking to get some nice 1mA). I made the tubes heaters wiring modification.
I already tried to swap one by one the tubes, the xfmrs, the cabling (internal and external), but nothing... I tested the relays and they work fine. Now I'm stuck !!
I tried to trace the signal with the same test tone on each bypassed/engaged channel with a DMM to compare them and found a strange behavior on B channel: The signal is getting very low at the input when I engage the B channel. Looks like a short somewhere in my circuit ?
When comparing I also found that for all tubes plates pins I had greatly lower voltages than the ones on A channel when the unit is engaged (like 230V vs. 150V).
If this symptoms tells you something, or if you can point me the right way to debug this channel, that would be wonderfull
Thx in advance.
Jerome
