bernbrue
You can print out the silkscreen. See first post.
Bernd
Bernd
brewbacca said:What value of fuse should this use? I'm in the US, but it would probably be good for EU people to know also.
Ok so those 5 tubes are enough then. I'll call the museum tomorrow and check tube status.bernbrue said:Hi John,
The prices for the tubes are quite good, especially for the 6386. You should ask whether the tubes are NOS (new old stock) or used.
There are 5 (6) tubes in this project. We made a solid state power supply so that the OB2 and 5Y3 are not needed here.
The 6386 is a very rare tube and hasn't been in production for quite a long time. That's why this double triode has been replaced by two pentodes (EF93) wired as triodes. This so called T bar adapter is included on the pcb. In other words: you can either use a single, quite expensive 6386 tube or two EF93 tubes instead.
I would grab the 6386 and the other tubes from Swedish radio museum and build it with 5 tubes.
Hope that helps
Bernd
