Just for information, I am now working on new versions of all the EZTube Mixer 3U EQ boards that include a gain make up amplifier. The first one I am building and testing at the moment and it is the 3 band Pultec version. I know I said I never made a 3U 3band Pultec PCB because of the problem of squeezing all the controls in, however we had a conversation about this many months ago after which I did manage to achieve a 3U EZTube module front panel layout for the 3 band Pultec. The only way this can be squeezed into a the module front panel space is by using 9mm pots. I guess it you replaced these with those tiny ELMA switches you could make a stepped pot version.
Thank you Ian! Cool
Is it possible utilizing a 3rd space for the eq controls? And maybe some preamp-estate as well? (2ch pre + eq)
Are all pots now on pcb? In that case you've really achieved much on little space.
I'm sorry I'm a little back and forth regarding what I would like to build,
but this will possibly be a once in a lifetime build for me, so I better get it right. Or leave it.
I'm looking forward to see your 3U 3bandPulteq
It seems to me that a 3U EzTube Lunshbox with 2ch preamp + 3band pulteq, all stepped, seems doabel,
when using frontpanel as one space, and using those greyhill switch boards.
Any major concerns for that idea?
Edit: Having 4 boards + flyed stepped pots on one singel frontpanel is maybe a little unpractical.
Maybe I should think separate panels.
1 space for preamp (with offboard stepped gain), and
2 space for eq
(I'll continue in the appropriate thread)
