Yes, I was just having a spare 2U 11"deep rack,ruffrecords said:The PMEQP1A MK2 PCB is 150mm by 50mm. It is not part of the EZTube Mixer range. It will fit horizontally in a 1U case but don't forget you also need to find room for the pots.
The 3U 3Band Pultec PCB was part of the EZTube MIxer range. It was never made because of the problems containing all the controls inside a standard 3U high module. I will delete it from that folder as it is confusing. The P3B.png is the original 3 band Pultec PCB layout. This pre-dates the lunch box design and is to0 tall to fit vertically in a 3U EZTube Mixer module. However, it will fit horizontally with ease in a 3U rack box - in fact it will fit in a 1U enclosure.
If you want to do a stereo stepped pot 3 band Pultec you need quite a lot of front panel space.
and although a 3bandPultec might be available for the EzLunchbox I don't know if a stepped version will be doabel there, preamp + eq. I understand I want much, but when thinking it through, making a 3bandpulteq, then it's not much more to add to get the preamp as well.
And planning using it for masterbus, then stepped is really important.
For masterbus it's more about the tube-sweetning than a master eq.
But then, one really just know how things work after finishing and trying it out
