Summing mixer Finished!
Hi!
After some modifications the final features will be the following:
NANOSUM 16 FINAL LIST OF FEATURES.
• Half rack size width (9,5" front panel + 9,5" rackmount kit).
(The case is smaller than 9,5")
• 2 TRS balanced expansion inputs, with a routing switch in the front panel.
• 16 stereo balanced inputs in DB25 Tascam®/ProTools® format.
• Inputs 1-4 configurable in Mono/Stereo by front panel switch.
(4 mono inputs total). Inputs 5-8 remain in stereo.
• Big potentiometer for precise control of master volume.
• 2+2 balanced outputs, TRS, for MIX OUT and multed MONITOR OUT (to an external monitor controller).
• Selectable BLEND circuit, with potentiometer for paralell processing of master insert. (Pre-fader).
• Insert points in the main outputs, TRS, unbalanced and half-normalled.
• Power led.
• 18VA AC external transformer(Alternate current) included.
• 2 years labor warranty.
+info, availability,  : https://mikrosum.webnode.es/nanosum-16-english/
