Have you seen the pan-pot arrangement in the Soundcraft 6000? It's even better. Check it in Technical Documents.Hi Guys.
It's been a while, bit busy with work
Btw, I decided to change the panpot design with the "Active Panpot". It base on xarolium design on his (SSL like), channel strip for S600 desk.
I suggest you use OPA2134 there. Actually dynamicaly quieter than 5532 in this position.
Well, it's actually the same.its bit simple and look the same like Douglas Self's design
Almost without exceptions, faders are unbalanced.This looks very exciting. Could somebody be so kind to explain why do you have to unbalance the signal before going into the fader?
.... Hoping they are not the same like those used for the SSL AWS console ( MK1 ),I really dig the k fader by alps as a great compromise of cost and quality. They feel good and are more serviceable than some other cheapies. Avid uses the motorized version in the s6L.
