RuudNL
Recently I serviced a Neumann M49C microphone.
The tube (AC701K) had become noisy and produced 'rustling' sounds.
Since good AC701 tubes are hard to find nowadays (and if you can find them they are very expensive ), I looked for an alternative.
I had noticed that the Great British company Phaedrus produced a solid-state drop in replacement for the AC701.
I had used the solid-state version of the VF14 in a U47 in the past with success.
So I ordered a solid-state AC701 and soldered it in the microphone.
The microphone worked, that is: sort of.
There was audio, but also a very obvious low frequency oscillation, 3 Hz. or so.
I contacted Phaedrus, but they never had experienced this problem.
The people of Phaedrus were very helpful, but could not give a good advice because they were unfamiliar with this problem.
After some experimentation, I found the cause of the problem and more important: how to cure it!
I reported my findings to Phaedrus and after that they released a Service Sheet for their AC701 used in a Neumann M49C microphone.
And that 'one case'... that was me!
