Neumann U64 XF
I don't know the exact specs, but isn't the BV107 also used in the km84?
Maybe easier to find specs with that in mind
just found this quote by bezen4uk:
"Hi James,
It has 7:1 ratio;
primary inductance is 400H (at 50mV~, 100Hz);
DC resistances are 1620 Ohm (pri), 66 Ohm (sec)."
hope this helps
"Hi James,
It has 7:1 ratio;
hope this helps
THANK YOU!
Bruno2000
