I have been wanting to make a good vintage mic pre for some time and the discovery of the Lorenz V-241 schematic from 1958 has now made this a possibility.
The interesting part about this design, is the use of a 150 Henry choke for the output stage. The V series mic pre's need special chokes made to order as they are 400H and over. You can buy a Hammond 150H choke for around $17 plus shipping. The reason why you can use this lower level of inductance is because the twinned ECC85 has an rp of around 9k, instead of the very high rp of a pentode. I have tested it and it's flat down to 10Hz.
Another factor that has made this a possibility is an affordable source of MuMetal foil from South Korea.
This arrived today, beautifully packed on plywood.
I have put one of the new LED lightbulbs next to it for scale. It cost $60 including shipping.
The V-241 has all its transformers and chokes in MuMetal boxes because it is crammed into a small rectangular box.
I shall be making mine in a 2u rack mount case, but I will still have to pay great care to layout and screening to achieve the lowest noise levels.
