I think you must search for the V241 also known as "Übertragungsverstärker ÜV300"Does anyone have the schematic for the first version of the Maihak V41? i.e. Not A or B as a post fix.
Yes this is really similar to the V41but the wiring of all the caps etc. is on the floor, everything else is the same. Apart from more components. The chassis is the same. The tubes too. I don't know which company made it? AWE B/76 is the only badge.I think you must search for the V241 also known as "Übertragungsverstärker ÜV300"
opacheco
Do someone knows what spec data have the input and output transformers, it’s turns ratio, primary and secondary impedance or it’s equivalente dB losses? Who made that transformers?...and there is the Telefunken ELA V41schematicView attachment 138786View attachment 138785
Which version do you mean? Maihak, Lorenz, Telefunken?Do someone knows what spec data have the input and output transformers, it’s turns ratio, primary and secondary impedance or it’s equivalente dB losses? Who made that transformers?
opacheco
DaveP,This schematic is marked V41, V41a and V41b and is dated in the 1940's, attached
best
Murdock,Which version do you mean? Maihak, Lorenz, Telefunken?
I think later ones were made by Malotki, the western at least. Input ratio was 1:18 (200:65k) and output transformer was 11.2:1 (38k:300).
Eastern V41 probably had other manufacturers.
Sorry, I have no idea!I think this a Maihak made unit, rigth?; I saw this unit have two output transformers! What was the use for it?
