Image Security
Norfolk - UK
Several times in the recent past when I have tried to upload a .png file I get an error saying my upload has failed security checks, please contact administrator. I open the image in Gimp, export it as a jpeg and upload it again. No problem this time. So, Mr. Administrator, why is this happening?
I don't know. This error still pops up occasionally but there seems to be no correlation with image type or the tools used.
I am just guessing like you all, but maybe GIMP (whatever that is) adds some unwanted extra foo into the image files that the security software does not like to see.
Like the old country doctor says, if it doesn't work when you do that, don't do that...
GIMP.
Gnu Image Manipulation Program.
It's like an open source (and free) version of Photoshop, available for most platforms. I've been using it for about as long as it has existed, and the only place I have ever seen have issues with the images, is this forum. So I'm thinking it's not actually the GIMP. It works everywhere else.
SMF forums are littered with people complaining about this.
The SMF check looks for certain keywords in the binary image data:  notably:
Code:
// Though not exhaustive lists, better safe than sorry.
 270          if (!empty($extensiveCheck))
 271          {
 272              // Paranoid check. Some like it that way.
 273              if (preg_match('~(iframe|\\<\\?|\\<%|html|eval|body|script\W|[CF]WS[\x01-\x0C])~i', $prev_chunk . $cur_chunk) === 1)
 274              {
 275                  fclose($fp);
 276                  return false;
 277              }
 278          }
 279          else
 280          {
 281              // Check for potential infection
 282              if (preg_match('~(iframe|html|eval|body|script\W|[CF]WS[\x01-\x0C])~i', $prev_chunk . $cur_chunk) === 1)
 283              {
 284                  fclose($fp);
 285                  return false;
 286              }
 287          }
 288          $prev_chunk = $cur_chunk;
For example, if GIMP inserts an HTML link it will fail this test.
Without a specific example, it would be impossible to tell which part of this is failing.
