saint gillis
Cheap Nice and Funky Amek 2500 preamps
« on: October 22, 2018, 07:39:34 PM »
  Hello, I made a quad Amek 2500 mic preamps rack, so here is the layout if some of you want to etch some single side PCBs :
http://sub-continental.com/diy_eng.html#amek
aviel
Re: Cheap Nice and Funky Amek 2500 preamps
« Reply #1 on: November 13, 2018, 09:11:37 AM »
Thanks! mind sharing the schematic you used as well as sound samples?
saint gillis
« Reply #2 on: November 13, 2018, 03:01:47 PM »
Hello, you can find the schematic on gyraf website's for instance : http://www.gyraf.dk/schematics/Amek_2500_micamp.gif
And the output stage is published on the webpage.
I don't think I will put samples but t's a quite renowned preamp and you can find opinions about it if you make a search..
gyraf
« Reply #3 on: November 14, 2018, 04:12:48 AM »
Very nice!!
We will need to know board dimensions in order to be sure to print it out to correct scale (more than 5% err makes it difficult to mount DIL ic's)
For sound examples I think we got the 2500 in 1982, for Karl Pitterson's recording of Steel Pulse's  "True Democracy" album: https://www.youtube.com/watch?v=h1L3tdNKnuY
Jakob E.
ed:link
« Last Edit: August 02, 2020, 10:38:23 AM by gyraf »
saint gillis
« Reply #4 on: November 14, 2018, 07:31:23 AM »
The file on the website is at the true dimensions (106,93 x 57,4mm   /  300px/inch).
The drawing is quite basic, you can add a bit of blank space at the back or on the sides to add mounting holes. I think I added two mounting holes at the back, so the boards hold between them and the pots.
gyraf
« Reply #5 on: November 14, 2018, 09:35:26 AM »
*like*
aviel
« Reply #6 on: November 22, 2018, 03:02:59 PM »
awesome!
i really have to learn to etch on my own
saint gillis
« Reply #7 on: March 31, 2019, 09:29:11 AM »
I was minding, between the two extremities of the gain pot, the offset is quite low (something like 4mV max) :
If we use a stepped gain switch, can we remove the coupling 2200ยต capacitor ?
gyraf
« Reply #8 on: April 09, 2019, 03:34:23 AM »
There are two current sources Q11/Q12 that set DC operating points for the transistor arrays - and I think you'd prefer to keep their two DC points different.
But that's theorizing: Try it, and report back?
Jakob E.
saint gillis
« Reply #9 on: April 09, 2019, 09:52:16 AM »
I worked on a preamp of the same topology , and I tried almost everything on my breadboard, unfortunately I didn't noted it all on a paper but I'm almost sure I tried the amek with or without gain cap and that it sounded the same...
gyraf
« Reply #10 on: April 10, 2019, 03:24:04 AM »
Might very well be so.
Maybe the big cap allows for wider variations in the transistor parameters?
Jakob E.
saint gillis
« Reply #11 on: April 10, 2019, 09:34:24 AM »
Maybe... also I'm not sure but I think there was still some few milivolts across the pot
« Reply #12 on: August 01, 2020, 08:39:38 AM »
Hi Saint Gillis.
I've finished it finally. Thank you for sharing the documents.
I found the 1M resistors are not in the BOM but in the layout, and I used SSM2142 that you suggested to me for replacing the THAT1646, It's hard to find THAT ICS here  ;D
I have some questions,
I forgot that the preamp needs +/-16V, but I have spare PeterC PSU that supplies +/-15V, can I use it? or maybe do some modification on it?
What current does the amps need? I have 5A trafo, is it enough for 4 channels?
Thank you  :)
Ricardus
« Reply #13 on: August 01, 2020, 11:40:55 AM »
I've been wanting to build some Amek preamps. I've worked on a lot of Amek consoles over the years and it would be cool to have some in my toolbox.
Audio mastering for hire..
mjrippe
« Reply #14 on: August 01, 2020, 12:52:29 PM »
Your +/-15v will do just fine.  I don't know the current draw of this circuit but I would bet the PSU can do +/-1A with good heatsinks.  Should be fine for four channels.
« Reply #15 on: August 01, 2020, 01:58:44 PM »
Thank you Mjrippe!  :)
Ipin
saint gillis
« Reply #16 on: August 01, 2020, 07:00:59 PM »
Yes I found 21mA per rail, so yes you might even not need big heatsinks..
Thanks for the 1Ms, I'll add them to the bom.
Nice looking job!
« Reply #17 on: August 02, 2020, 08:19:32 AM »
Nice looking job!
Thank you very much Saint Gillis  :)
Ipin
« Reply #18 on: August 04, 2020, 09:23:56 AM »
Hi Guys,
I tested the preamps today, and no sound, just humming from both channels.
Here is my ICs voltage chart (both channels are nearly the same)
Without NE55322:
1. 14.5
2. 14.7
3. 14.7
4. -14.9
5. 14.4
6. 0
7. 0
8. 15.0
Without TL072
1. 14.8
2. 10.0 (dropping till 7.4)
3. 10.0 (dropping till 7.4)
4. -14.9
5. 7.4
6. 7.4
7. 14.8
8. 15.0
Without SSM2142
1. 0
2. 0
3. 0
4. 0
5. -15.0
6. 15.0
7. 0
8. 0
I checked all the soldering and it's all fine, nothing short.
Does anybody know what happened here? Is it bad ICs? Or Transistors? Or Caps? Because its happened on both channels
Thank you
Ipin
« Last Edit: August 04, 2020, 11:07:24 PM by ipindalieson »
Ricardus
« Reply #19 on: August 04, 2020, 07:40:02 PM »
Seems like this would be an ideal 500 series circuit.
Last post December 07, 2008, 08:56:25 AM
by pedroplanet
Last post March 30, 2008, 05:49:54 PM
by barclaycon
Last post June 10, 2005, 04:36:20 PM
by SSLtech
Last post August 10, 2006, 09:03:15 PM
by 12afael
