Re: Advice and ideas for a mixing console build
« Reply #40 on: October 30, 2018, 05:31:29 PM »
I love the idea of a removable mic pre/eq module like on the old Neve's and trident desks. While it does up the cost a bit it does make it plausible to run those modules separate from the consoles for remote recording.
Many large format consoles are built highly configurable.. I may have gone a little overboard with the frame though, one could fit a lot more features into it than what I originally sketched in the schematics.
Another thing I've been thinking is whether I should make the fader section modular for easy service.. at first I was thinking fixed configuration, perhaps because I was intending the console for summing. Faders are dirt cheap though.
Thanks for the ideas anyway!
pucho812
« Reply #41 on: October 30, 2018, 05:43:00 PM »
While that is true, most do not let you remove the mic pre eq and just plug it into a rack and go.  there is usually some sort of hoop to jump through.  As we migrate further and further forward we loose those things.  for example the new ssl's are not as modular as the older ones.
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
« Reply #42 on: October 30, 2018, 05:47:53 PM »
I was thinking mic pre modules instead of kits.. eliminates the need to look for bad solder joints and components etc, and means less solder work. The obvious downside is serviceability though..
« Reply #43 on: October 30, 2018, 05:56:33 PM »
We should do a gdiy console project. I plan on 24 buss and 8 auxes because I still have that desire and need to a degree.  Plus it's becoming more rare to do.   If anyone wants to trade ideas around maybe we can get to doing it.
I think a "charity" console idea is great.. I was thinking a very similar concept with PA the other day.
« Reply #44 on: October 30, 2018, 06:14:56 PM »
Good one aren't cheap.
« Reply #45 on: October 30, 2018, 06:16:36 PM »
Removable modules were invented primary to improve serviceability. It's an upside not a downside.
« Reply #46 on: October 30, 2018, 06:17:13 PM »
A better word would be community.
« Reply #47 on: October 30, 2018, 07:55:37 PM »
Yes but the ones I can fit in there are... the ALPS for instance have a very high profile.
Meanwhile, I've been working on a linear PSU..
boji
« Reply #48 on: October 31, 2018, 12:59:50 AM »
My second piece would be that 3U high 500 series modules are too small for this.
It's size seems perfect for non-tube pre's but I agree they get a little tight with full featured eq's.
I chose that format because they have become fairly a standard. There's so many 3rd party offerings of all sorts, diy and commercial that is seems like a natural choice for a modular  'community' mixer, at least in the pre section.
Brian Roth
« Reply #49 on: October 31, 2018, 01:23:30 AM »
500 modules make  sense for preamps and EQ's.  That was the original intent.
So what happens when you quickly run out of edge connector fingers in the 500 format for stuff such as busing and auxes and yada?
Bri
Brian Roth Technical Services
Salina Kansas, home of the best vinyl on the planet!
http://www.BrianRoth.com
recordingservicesandsupply.com/
www.qualityrecordpressings.com/
store.acousticsounds.com
« Reply #50 on: October 31, 2018, 02:49:32 AM »
Bri
Exactly. You need something taller  with more I/Os for routing modules. Maybe a double height module with two connectors?
iampoor1
« Reply #51 on: October 31, 2018, 03:17:38 AM »
I believe classic API already has the metalwork available for building a console in the 500 series format?
« Reply #52 on: October 31, 2018, 08:08:09 AM »
Built the 12V version of the ESP mic pre.. I believe it works to some extent.
JohnRoberts
« Reply #53 on: October 31, 2018, 11:39:34 AM »
Back in the 70s-80s when I was running my kit company I considered offering a modular kit console/mixer. I ultimately abandoned it for a couple reasons.
#1 the primary reason people bought kits (at least back last century) was to save money. A kit modular console would actually cost more than a cheap (made in Japan) value mixer of the day. This was before mixers from China got silly cheap in the 1990s.
#2 The design task to make a truly flexible, fully configurable mixer/console, means you have to anticipate all the possible future configurations to incorporate the hooks into the basic design. Even if you don't populate all the features for a basic mixer, you burn the PCB real estate and connectors. If you want lots of buses you need a line or two for each. In hindsight I am kind of glad I didn't do this kit program.
I know several people who have built one DIY console for their personal use, nobody who ever built a second one.
John Roberts
http://circularscience.com
Tune it, or don't play it...
boji
« Reply #54 on: October 31, 2018, 12:00:52 PM »
Just add another 500 bucket à la Jeff's kits?
Also:
https://www.purpleaudio.com/products/moiyn/
pucho812
« Reply #55 on: October 31, 2018, 02:50:25 PM »
One of my clients has a custom console by the folks at tree audio.
It has 16 channels that have 2 x rows of 500 slots to allow 2 X 500 modules per channel.  It seems like a great idea, I can add 500 modules to a channel strip that has auxes, busses, panning, mute, solo, etc.  that's the upside it is customizable I can build as I go, add what I want, etc. The downside is if you do not already own the 500 series modules, it can get real expensive real quick to fill it up.
boji
« Reply #56 on: October 31, 2018, 04:08:40 PM »
Ain't that the truth.  Also since the channel section and patch seriously test one's endurance, the thought of diy-ing another 32 modules is...
Two kidneys right? We technically only need one, so...
pucho812
« Reply #57 on: October 31, 2018, 04:16:36 PM »
I got it. for auxes, buss, pan pot, mutes and solo cards, just use ye standard eurorack connector, everyone else does.  ;)
« Reply #58 on: October 31, 2018, 10:56:40 PM »
Here's a pic of a prototype channel strip in the making..
« Reply #59 on: November 01, 2018, 03:59:20 AM »
Image not working for me
Last post April 09, 2012, 03:55:50 PM
by living sounds
Last post June 04, 2010, 02:05:23 PM
by Rob Flinn
Last post October 05, 2011, 10:10:56 AM
by gary o
Last post December 28, 2011, 02:06:45 PM
by r2d2
