With U47 sound I mean huge proximity effect and range, meaning the bass respose is great even from a distance, good transients (no prolems with plosives or sibilants), smooth frequency response though a tad mid forward, with velvety smooth top-end. The mic breathes with the singer.
Obvious limit with the P48 phantom powering is the lack of the power. You don't have much more than 0.5 watts available. Using proper high efficiency DC/DC converter for powering the amplifier instead of a resistor and zener you could obviously get much more out of it but I haven't seen it done for powering the amplifier section. With more power available you could play with the classic Class-A circuits, obviously you can't put LO1166 inside mic but maybe into PSU. Anyway, you get the idea. In same cases you could bypass the mic pre altogether like is done with the REDD microphone though using tubes: https://chandlerlimited.com/redd-microphone/
The TG microphone though has lower output level:
https://chandlerlimited.com/tg-microphone/
There are also the 3U audio Warbler mics which have different voicings available, that would be another thing to consider:
http://www.3uaudio.com/cp.asp?id=685
Quite too often the microphone sound is tried to be explained using a two dimensional frequency response plot. However, there are resonances which cannot been seen in 2D snapshots and which color the sound a lot, also those problems cannot be fixed using EQ unless they are purely minimum phase symptoms. So you can't "voice" a mic with a K67 capsule to one with K47 for an example, might get half way though.
