- Joined
- Apr 10, 2016
- Messages
- 81
Gus said:look for PN
A-8262-982-A
https://sony.encompass.com/item/1452280/Sony/A-8262-982-A/
A-8262-982-A
kingkorg said:Judging just by the size of the original transformer i would bet it was designed to be ultra transparent. Which makes things easier, as vintage "vibey" are tough to replicate, this one should be easier. But i am just guessing.
Why do you say this? I know they are the same type of capsule.. but what would make the Neumann a stronger choice , or what would make the Sony capsule a stronger choice?built a moded quite a few..
Just use k67 Neumann in this. a lot of the sound of this mic is the long body Russian 6au6a at 5.7v and the coupling cap.
did you ever end up doing a build?Interesting... I am also in the process of trying to build a replica. I found the Sony capsule for sale but they do not have the transformer for sale or the tubes. The tubes seem possible to source but the transformer might be more difficult, since like the capsule I would assume Sony has a "special" transformer but again thats just an assumption. I have all of the schematics and some have voltages listed. I also have manuals for the mic and power supply which have detailed schematics and a parts list. Id love to see how you accomplish a clone of the C800G. I will definitely follow this thread if anything develops.
In a Japanese article, it says that the C800G transformer has a ratio of 7:1..6:1 ratio
This is exactly what I tried to do - convert the jpeg image of this article into text format for further translation.
In the available sources of technical documentation for the c-800g, I have not read anything like this anywhere.The ratio is almost irrelevant. The point with that transformer in that mic is to be as transparent as possible. I't doesn't color the sound.
