dan2804
MADI to Ravenna converter
« on: October 02, 2019, 07:50:55 PM »
Hi all,
I'm looking for a way to convert 6x 56 channel coax MADI streams into the Ravenna AoIP protocol.
I know there are one or two boxes out there capable of converting MADI to AoIP, but they are generally quite expensive and have a lot of features I don't need, so I thought I'd turn to here since I've seen some DIY MADI solutions.
I don't quite have the technical knowhow for board design or FPGA programming, so any help would be great.
In a nutshell all I'm after is a way of converting 6x 56 channel MADI streams with a direct one to one patch to the Ravenna AoIP protocol. I don't need any fancy DSP options, custom routing matrixes or anything like that. Just something I can plug into my network and patch on the network.
I look forward to hearing what you guys have to say about this
Rogy
Re: MADI to Ravenna converter
« Reply #1 on: October 03, 2019, 05:33:21 PM »
Probably the madi side of this would be the easier part; I guess the AoIP part is more complex as it deals with many protocols (PTP2, RTP, QoS, ...)
Should you decide to go for an off-the-shelf solution, please find some suggestions below:
https://www.directout.eu/en/products/montone42/
https://appsys.ch/en/products/digital-format-converters/multiverter-mvr-64
Best regards,
Rogy
dan2804
« Reply #2 on: October 05, 2019, 10:27:34 AM »
Hi Rogy,
I am aware of the converters on the market (as I said in my original post), however a lot of them become very ineffective in terms of cost when you need to convert more than 4 MADI streams to AoIP.
In terms of the AoIP of the converter, there are plenty of modules from Audinate (both as a little plug in card and full on FPGA IP Core) as well as Merging Technolgies (Zman) and a few others.  AES67 is opensource, so getting hold of FPGA code, etc isn't the hardest thing to do, so worrying about PTP, QoS (which is configured on the network swtich, not the audio device), etc again wouldn't be too hard providing there was something to go on.
I would build this myself, however circuit board design is really not my forte, so I wouldnt even really know where to begin on that side. Software wise I have some idea, but would need help getting it off the ground
Last post January 15, 2019, 08:25:37 PM
by Potato Cakes
Last post May 21, 2019, 09:34:20 AM
by zqone537
Last post February 09, 2020, 03:26:40 PM
by jplebre
Last post April 24, 2020, 10:04:09 PM
by tommytones
