BluegrassDan
One last check. B+ decoupling caps necessary?
« on: March 29, 2020, 02:43:26 PM »
Howdy,
I am elated with this design. It sounds great and has great specs on paper. Just one more question.
Do I need any sort of decoupling caps on the B+ anywhere in the circuit, and if so, where?
This is powered with an external PSU and umbilical cable. My thought is what might happen when adding multiple channels in a single chassis. Will there be potential for crosstalk without decoupling caps.
Thanks in advance.
Re: One last check. B+ decoupling caps necessary?
« Reply #1 on: March 29, 2020, 03:09:07 PM »
from RDH3, chapter 4
BluegrassDan
« Reply #2 on: March 29, 2020, 03:27:34 PM »
I have read that, but I was curious about when a third stage is a White follower. Plus the other two cathode followers.
« Reply #3 on: March 29, 2020, 04:43:53 PM »
I would certainly decouple the first stage HT because its PSRR is poor and there is a lot of gain following it. You definitely want the quietest supply you can get for the first stage. A 10K series resistor and a 10uF decoupling cap will give you over 35dB attenuation of 100Hz. Up it to 100uF and you get over 55dB.
BluegrassDan
« Reply #4 on: March 29, 2020, 05:43:08 PM »
How's this look?
« Reply #5 on: March 29, 2020, 06:11:17 PM »
How's this look?
Looks good to me. Not sure about the 7K5 cathode resistors in the two triode gain stages. What current does that make them run at?
ian
BluegrassDan
« Reply #6 on: March 29, 2020, 06:15:36 PM »
The RCA BC3C runs 8.2k 1W cathode resistors.
« Reply #7 on: March 29, 2020, 06:49:33 PM »
yes, and un-bypassed ,  as the  preamp is wrapped in feedback.
the EIN of a BC-3c preamp  hardly stellar.
« Reply #8 on: March 29, 2020, 07:13:56 PM »
 But in the OP's amp the first stage cathode R is bypassed so the resistor makes no contribution to the noise performance. Looking at the data sheet it looks like quiescent current will be around 0.5mA which is probably OK.
BluegrassDan
« Reply #9 on: March 29, 2020, 07:24:38 PM »
EIN is not bad at all.
« Reply #10 on: March 29, 2020, 07:45:32 PM »
I am not sure how that pic shows EIN.
BluegrassDan
« Reply #11 on: March 29, 2020, 07:50:14 PM »
It doesn’t, per se. But it’s one example of noise floor.
Last post April 17, 2008, 01:02:56 PM
by mkoijn
Last post December 07, 2008, 07:14:57 PM
by gswan
Last post May 08, 2010, 04:08:28 AM
by mikeyB
Last post November 08, 2010, 10:51:00 PM
by Rochey
