Any switching power supply will have an inductor on the output,
Correction, every SMPS should have a second LC filter. It's surprisingly uncommon and mainly because few "SMPS Designers" actually understand how the SMPS feedback loop really works.
Extra LC, especially small and cheap has DCR and affects DC Regulation. Trying to take the feedback after the LC filter causes stability issues if the filter actually does something.
There is a simple solution we know from Audio Amplifiers, namely Cherry's "NDFL" adjusted to operate across a "slow" optocoupler. But that needs more than copy/pasta.
his description of the circuit is that it uses the parasitic resistance and intrinsic inductance of that component as the series element before the shunt device.
Precisely. Wire DCR, trace DCR all also count.
Say we have 10mV audio band noise, mostly 100Hz.
We have 50mOhm DCR in the system (mainly inductor DCR).
How much current must be drawn on the far side of the 50mOhm to make 10mV appear across the 50mOhm resistor?
0.2A.
So we would have a chunky heatsink and 0.3A quiescent current allowing for 0.2A RMS, maybe 0.4A for "Arbitrary Waveform".
Or switching to an AB output (implies capacitive or inductive coupling) may be preferable if we have SO MUCH noise to kill with so little DCR.
If the current frequency, phase and amplitude in our shunt "current sink" is correct the totality of the noise will appear across this resistance and the output will be noiseless.
In reality we never get 100% but 60dB below 10kHz are quite easy without any adjustments and mass production reliable, using feedback.
Wenzel shows Feed forward, however the conversion to feedback should be obvious. Feedback allows very large audio band noise reduction with basically parasitic resistances as ballast.
The 0.3A quiescent current also illustrates the limitations. It is better to start with a fairly low noise PSU if we want to "finesse" noise.
BUT it works without any DC voltage drop (except a few 10mV), to it is the ultimate "LDO".
And it means we can keep Agency compliance, EMC etc. to people who and live and breathe it and often can certify in house even FCC, meaning it costs essentially nothing in China.
With a Constant Current LED Supply applying a DC shunt regulator and decent LC pre filtering could be a really good choice, if we are prepared if needed to burn up the entire CC current.
Again, 5534 plus shunt transistor can work great. I like to hang a PNP or LM337 off pin 5 for that, dumping an extra few mA into pin 5 to wake up the third stage npn transistor a little.
There are also tricks with the 5534 to up the 2nd stage current (and we can add our own degenerated but still lower noise external input differential) that work just as well here as they do in audio applications.
Thor
