Capsules and relative humidity
McIrish
In Ari's long thread, it was mentioned about capsules being drawn to the backplate due to low humidity. I had heard that high humidity can cause noise issue but I never heard about low humidity problems. I've been keeping all my mics in sealed their boxes with desiccant packs. Now, I'm wondeing if I'm doing it wrong. My studio is typically 45% RH. Maybe I just leave out the desiccant packs?
keep your mics in tyvek if your studio is at 45%. that way the moisture from use can evaporate out but it won't get dry enough to damage the capsule. desiccate above 70% rh.
Tyvek? The construction fabric? How would that work? Does it come as small bags? I've only seen it in large rolls to wrap the exterior of a house before siding.
Thatnks for the knowledge and clarifications.
Here's one example:
https://citadinedesigns.com/collections/small-pouches
And: https://mediwish.com/product/pharma...pgqLdQQZUVnbY93lqMFUJwmtRsQhA7Dyz4-cFXM&gQT=1
And these from the Post Office: https://store.usps.com/store/product/priority-mail-tyvek-envelopes-P_EP_14
Low humidity can damge capsules?
oh yes. in low humidity, the mylar can no longer discharge environmental static and can stick to the plate even without being hooked up to anything. this is the reason behind the little plastic dots on the backplates of vintage neumann capsules. drove them bananas.
Can you show an actual example to substantiate this?
The only time I have seen anything remotely like that is from PSU failure.
I just mean, showing many or even one where this has actually happened, as opposed to picking a capsule and then actively doing anything to destroy the capsule.
The claim has been that this was so common that it was Neumann’s bane. There must be many pictures of this floating around then.
I don’t want to be snarky, so I will bring the subtext fully forward; I somewhat doubt the claim. I am happy to learn something new though, and/or have my suspicions assuaged.
It's difficult to notice this happening actively, usually I notice telltale signs of this in capsules that have been in storage lockers over the winter. It leaves these weird marks. I've seen this happen to two Neumann capsules so far live but I don't leave them like that and I've pretty long since started humidity climate controlling my office so it hasn't happened in a minute. Maybe someone else has pictures? There's nothing I can do to prove this other than hearsay or destroying an existing capsule to show you
But to ask an important question, do you really think they would go out of their way to add tiny dots to every single backplate they make for like a 10-year period just for the rare instance of PSU failure?
Yeah, don’t let yourself feel compelled to destroy an existing capsule because that definitely would not convince me that the production issue you are having is very common in actual Neumann capsules, or Gefell, and Thiersch for that matter.
I’m not trying to bust your chops. It seems worth determining if this is based in reality before it is repeated endlessly from here on out.
I have definitely seen a membrane sucked against the backplate from PSU failure though.
It's not very common in mine either to be fair. The set of circumstances that need to happen are very specific. So far this has happened to approximately two out of about 2500. Not a tremendous amount but enough to be annoying
It's also important to understand that these problems compound. The membrane getting permanently stuck to the back plate from PSU failure is more likely the lower the humidity gets. These are not strictly speaking separate problems in the first place. There's also the vacuum effect that makes this significantly more likely in k47 capsules then in k67's that have a rather large central vent of course. This is one of a few reasons why they tried so many ways to put a hole into the M7. Though PVC is way less prone to this
This I understand. It's difficult to walk through all the subtle changes made to try to avoid this problem without units on hand to show what I mean. There's definitely a progression of getting more and more frustrated about this problem (the membrane sucking into the back plate in general, not just from environmental static but also PSU failure) in the design of the capsules over time. I'll try and get some non-destructive examples together. I definitely don't want to contribute to spreading misinformation. Klaus accidentally implied once that all k67 chamber spacers are 40 micron and it made at least two Boutique capsule manufacturers that I've met in the wild not check. I don't want to cause something like that
To clarify, I would have used one of the capsules that this has already happened to. I kept one of them that it happened to to document the damage haha. I wouldn't just a nuke a random perfectly working capsule, not that it affects performance much. Also, of course can be related to diaphragm conditioning, but why do you think they condition the diaphragm the way they do in the first place? "this couldn't happen to Neumann capsules because of how they precondition their diaphragms"/ have higher tension is a bit like saying "how could anyone ever die of polio? There's a polio vaccine!" Yes. A polio vaccine designed to prevent polio. Before which, polio was prevalent. Which is what prompted them to develop a polio vaccine. You know? I'm not saying this problem is common in current Neumann capsules. It happens to a couple vintage Neumann capsules capsules and also a couple of my capsules, because they are clones of vintage capsules. They are exact clones and that includes having all of the problems that the vintage capsules had, something that I am not denying. Heck, my lower tension units that are more prone to this problem come with a literal disclaimer card:
Though even this is an overstatement out of an abundance of caution. This is not a secret nor something that I particularly shy away from. It's also important to note that this doesn't really happen to capsules that are installed in microphones because the environment is so different. It's only really a thing that happens to spare capsules in boxes, and only in situations where they can pick up a lot of environmental static, like while being shipped in retail volumes.
This happens slightly more often when the film is desiccated during heat treatment and then immediately sent somewhere very dry and cold. It can be mitigated by rehumidifying the film to some degree after drying which I believe is what Neumann does with modern units but there are a couple reasons why I don't do that as extensively. I do do it but not as much. Mostly that it's really hard and I'm poor and it barely happens, like to one in every couple thousand units at the diaphragm tensions I use. Which while lower than current Neumann production are still sane. Eventually I will implement the changes to the diaphragm conditioning that Neumann did. Right now I'm only doing the preconditioning they did in the 70s which constitutes roughly the first half of the process that they do now by my reckoning. I also actively make this problem worse by shipping my capsules with silica gel packs because this problem is still rare enough that it's not as common as issues caused by in-box condensation.
This is also something I want to touch on because I didn't say it was common. I said it bugged them. Those are two super different statements. Just because it bugged them so much that they went through a half dozen revisions to the capsule to solve the problem does not mean it was common. It just means they're eccentric. Do you have any idea how hard it is to make 20 Micron thick plastic dots on a brass back plate? Doing that in the first place is completely insane. This happening to one of every couple thousand or even 10,000 capsules is an engineering problem and a point of pride to Neumann. At least that's the impression that I got. I have no confirmation of their motivation. Though I relate if that's it. This problem happening twice ever in the 5-year history of my production was enough for me to print disclaimer cards. Broadly I feel like at least one of the engineers at neumann was the same type of person as me. Judging from the very strange and difficult solutions they came up with for this problem. That's part of what makes me so passionate about this! The people who worked on these products were so over the top. I feel a kinship looking at this occasionally wild and wacky nonsense. Do they need to cut the chamber gap in the k103 with a lathe? Of course not! That's completely insane! But it's fun. They're having fun! I'm having fun. I firmly believe that when they went through revisions trying to solve this problem, they were doing it mostly for fun. I think I might have not communicated very effectively here.
The next logical question one might have would be "are you implying that they compromised the sound quality of all of their capsules to solve a problem that only affected one in every couple thousand units?" And the answer to that question is that that's not really an accurate framing of the problem as it's presented to them as engineers. That's the enthusiast perspective. I'm implying that they decreased the bass response of their capsule slightly. "Compromised" is a value judgment that doesn't really factor into it. They slightly decreased the bass response in a way that the final curves are still within the bounds that they set for their unit qc, so that they could move on to objectively better microphones that their customers won't buy. Again I'm speaking from an engineer's perspective, the consumer perspective is very different. These are all highly multifactorial decisions though. There's also other motivations in there like very precisely optimizing the capacitances of their capsules. They do all sorts of little stuff like that. They're Always optimizing tiny things. I wonder if it's to keep from going crazy having to make a microphone that they don't even want to still be making using technology that they personally consider obsolete.
I love all the history and completely respect the passion and logic here.
I think there are a lot of folks who are ultimately wondering the same thing I am though - how should we store our microphones?
I have personally had to repair a number of microphones whose capsules have suffered drop-outs due to accumulated hydroscopic material on the diaphragm causing conduction between the gold sputtering and the retaining ring/backplate. For this reason, I have recommended clients store their condenser mics with a silica packet. I have always done the same and have never had issues.
I (like @McIrish) took your comments in the capsule thread to mean that we shouldn’t be doing this. From your comments in this thread, it seems like this is more of an issue with capsule storage and not so much with capsules that are in mics.
TLDR - desiccant packet - yes or no?
TLDR - desiccant packet - yea or no?
I am always a proponent of controlled humidity over full desiccation but there are pros and cons to both approaches. When you're transporting something it's better to fully desiccate because of the risk of condensation. It's also probably better for the amplifier electronics for it to be fully desiccated? But it's not necessarily good for the plastic of the capsule to be fully desiccated. But you also don't want it to be humid.
I have never felt comfortable with the amount of detritus that comes out of desiccant packets. Shake one over paper (or whatever) and then shine a UV light. Yikes.
Most mics are designed to function fine at typical environmental humidities, and many can even work fine at extremes. It is the breath humidity, spit, and dust. Spit sticking to the capsule, dust sticking to the spit, then more humidity from breath making the dust moist and creating a short.
I really like open ended polypropylene sleeves + mic box or an extra mic bag for long term storage. Hefty bags and such are fine too. The Hefty storage bags are great for putting over mics on the stand.
As long as the mic is at ambient temperature when a bag is placed around it, there won’t be condensation inside.
