1176 best low noise build
I’ve opted to use some 24v bulbs I had I didn’t know how much current to give them but experimented and ended up liking 27ma at around 18v seemed to light them up nicely.
I wanted to use 3 of them, 2 for both VU meters and one for a front panel jewel light.
So using the 180 ohm 10W resistor with 37v off the diode bridge gives me what I want.
I have some 22k switched pots for the attack pot but the switch is disconnected in the CCW position, can’t seem to figure it out with the switch this way??
Channel 1 isn’t playing ball, for some reason signal is only getting to q1 drain and no further? I’ve put in a brand new 2n5457 and checked the pin out?
Will try another fet but I’ve also changed q2,q3 and q4 and used scope but no signal through?
I’ve checked all resistors and checked all continuity through the first and second stage.
Also checked all voltages and all voltages are fine?
