R46 (47k) is now 22k
130k is now 68k
jumper is now 47k
130k is now 68k
jumper is now 47k
ilfungo said:Thanks
I have changed the 3 resistors
and the unit it's more controllable...
In nuke mode must be more light with input and attach pot...
I have used attack pot with off switch
from hairball connection but I don't understand pad 22 where is connected,
is connected to the ground?
Ciao![]()
ethervalve said:Hi all,
I'm in the same boat as Stagefright13 (I already finished my pair of blue strips and love 'em). I have no interest in the slam mode, i am intrigued by the r46 mod. i would prefer if the threshold were higher (particularly for 1:4), but would this resister swap mean that i would have to completely re-calibrate? I had some difficulties calibrating and i would prefer not to go down that road again for a while.
thanks in advance for any insight.
Neeno said:I've got the values comparing the Rev A schematic to the one used by Mako (Original 1176) which are the ones between parenthesis.
la-2a said:Here some informations about the pushbotton resistor values.
Hope this helps:.!! I´ll make some highres pictures next days and post them here.
cheers
Neeno said:...
Now, it would be just great to have some high resolution pictures...
zmix said:Neeno said:...
Page one of this very thread has some pretty clear photos of the internals of my original bluestripe, someone could check these resistor values against the various schematics...![]()
Biasrocks said:zmix said:Neeno said:...
Thanks for those!
I did check your photo's against the schemo. It turns out that yours is a REV B which doesn't have the dual FET pre-amp.
The info, we're looking for pertains to the earlier versions with serials under #216. A truly rare beast, but it looks like we might be getting closer. 8)
Mark
