ChuckD
Thanks TubeJay!
I put the grounds together as you described but it is not the problem.
I've isolated the problem to a ground loop between the two boards, I know this because if I unplug one then the remaining goes quiet.
So If I unplug just the PIN 1 of one of the channels (both input and output) I get quite operation. Now is this ok to do this? Is the signal with no PIN 1 still balanced? Can someone explain this?
What are some other solutions? I dont have another transformer and really would like to use only one.
-ChuckD
-ChuckD
