leanlowkey
Active member
if I have a 2 channel mic pre that im using for my mixbus can I run both channels to the same knobs so I dont have to "match" settings I can just turn one set and itll adjust both channels equally?
thanks
thanks
True, there will be some variance, so depending on what level of precision the OP is looking for, a dual pot may or may not be a good solution.Just be aware that dual potentiometers usually don't track well between sections.
Bri
Not only fast but also very flexible in emulating the control characteristics of various compressor/limiter classics. An exciting idea. Digital sidechain?😎Thinking about it for a second ("where could these be useful?"), these could be used to make the worlds fastest compressor. 🤔
