ok, i did not see the moderator thing, i thought you were slappin people down just for the heck of it,
ok, 2 choices for experimental transformers right here>
now there is a transformer already in the mic, if you try to replace this with a transformer with ten times the turn ratio, you will probably run into problems, you would save some core loss since you are only exciting one core, but the turns ratio would be too high.
pri z,
try 500 turns on a square stack of 94EI
mag metals catalog says for 94EI,
L = (0.0401*10^-8)KN^2(u-ac), u-ac = perm = 100,000 for mu metal which we will use for ultra low loss mic signal, K is stacking = 0.9 or abouts for 3 by 3 laceup,
so L = (0.0360 * 10^-8)N^2(100,000)
L = 0.0360 * 10^-3 * N^2
so if N = 500 turns, we have N^2 = 250,000
so L=(0.0360*10^-3)(250,000)
L = 9 Henries for the primary.
so our Z will be reactance for 9 henries at 50 hz,
XL = 2 pi f L = 6.28 * 50 * 9
XL = 6.28 * 450 = 2,826 ohms at 50 hz.
henries for the sec will 10^2 times 9 = 900 henries.
sec Z will be 6.28 * 900 * 50 = 282,600 ohms or about 260 K.
so a high Z input will be needed to make this work without dragging down the signal on the sec.
or, we could drop the pri Z down to 200 ohms, they say that max pwr transfer is when source = load, so if the mic trans has a 200 ohm sec, we will plug it into a 200 ohm pri and see what happens.
ok, so we can reduce turns on the pri (and also sec) if we only need 200 ohms,
but how many turns = 200 ohms?
reverse engineering, 2 pi f L, 200 = 6.28 * 50* L
200 = 314 L, L=200/314 = about .67 Henries.
so plug 0.67 into the inductance formula, which was simplified to
so turnssquared for 0.67 henries = 0.67/0.000036 = 18,611
take the root and you have your turns, root of 18,611 = 136 turns.
sec will be 1,360 turns, sec z will be 200 * 100 = 20 K, which should be ok.
we already saw that 100 turns would be no problem as far as max flux and saturation,
now if we draw all the power out of the mic motor with a 200 ohm pri z hooked to the mic, what will happen?
me thinks the signal will drop,
so maybe a 94EI with more than 136 turns but less than 500 might work, if plugged into a relatively hi z input,
what is the input Z on a mackie 1604?
1.3 k, wtf, over?
ok, this transformer idea is looking like a waste of time and money,
i suggest a cheap 20 db preamp would be the best option,
if you drop the input Z on the mic, you lose signal.
if you raise the input Z on the sec, you lose signal.
so i guess the dead guys had it right, there is a certain point at which you have to jump from passive to active in order to get the best signal/noise, and it appears that a low z mic motor into a trans that outputs 200 ohms into a amplifier is the best way to go.
however, sometimes experiments prove theory wrong, so it would still be fun to fool around with a 94EI with 250 turns and clip the input resistor across the mackie opamp.
next...
