C Coop Well-known member Joined Apr 22, 2013 Messages 92 Location Austria Jan 3, 2022 #21 @Golgoth You're welcome Do you have the BA338 schematic? @SIXTYNINER Some pics and measurements
Golgoth Well-known member Joined Jul 24, 2015 Messages 342 Location Paris, France Jan 3, 2022 #22 @Coop You can find the BA338 schematic on page 19 here: https://www.technicalaudio.com/pdf/Neve/Neve_1081_manual.pdf
Golgoth Well-known member Joined Jul 24, 2015 Messages 342 Location Paris, France Jan 6, 2022 #23 @Coop By the way your wiring is done per the 1073 schematics is that right? For the input transformer are you using pin 6 for grounding in your pigtail? I have never seen that before. Last edited: Jan 6, 2022
C Coop Well-known member Joined Apr 22, 2013 Messages 92 Location Austria Jan 7, 2022 #24 Yes, it's the 1272 wiring actually. Yes, Pin 6 is used for grounding as per the schematic.
Golgoth Well-known member Joined Jul 24, 2015 Messages 342 Location Paris, France Jan 7, 2022 #25 Ah yes! I could have guessed that it's in the thread title haha! Didn't know there was a B283 fitted inside that's module. Do the TO3s heat up a lot? The original 1272 case looks so tighly packed with cables directly above the BA283 card! Last edited: Jan 7, 2022
C Coop Well-known member Joined Apr 22, 2013 Messages 92 Location Austria Jan 8, 2022 #26 Well they do get warm but not so hot that they can melt a cable.
S SIXTYNINER Well-known member Joined Sep 15, 2005 Messages 779 Location ...Somewhere In The Infinity Jan 11, 2022 #27 Coop said: @SIXTYNINER Some pics and measurements Click to expand... Much thanks for info , is the thickness 3 mm ? cheers
C Coop Well-known member Joined Apr 22, 2013 Messages 92 Location Austria Jan 11, 2022 #28 @SIXTYNINER You're welcome. Thickness should be 3mm if I remember correctly
