@Don,
Sorry for my noob question,but I want to get the pan board situation right.
Also I'm not too familiar to the grayhill switches,have done only some of Jeff's modules so far,right after his descriptions.
So first question is how to get a center position.
Assuming we want 10k overall resistance for a 12 position switch,am I right then to take positions 1 to 11 to make pos.6 the center?If so the 10 resistors needed would be 1k each to get a linear function as they're easy to source.
Jumpering the "w" resistor position will be my former "12" when in end position.
How do I set the stop pin on the grayhill,put it to point 12,is it that simple?
Looking forward to an answer,
Udo.
Edit:It's not a linear function,forget about that,excuse me!
But about setting the stop pins on the gray hills,am I right with it?
So e.g. your schemo showing a 7 position solution I would set the pin to point 8,no?
Thank you again,
Udo.
