At one point my brother and I were going to build a small tube mixer but we abandoned the project. Here's the EQ we were going to use.
It's based on the Jeffery high gain phase splitter to get very high gain from a pentode. Wireless World, August, 1947, page 274
http://www.americanradiohistory.com/Archive-Wireless-World/40s/Wireless-World-1947-08.pdf
Cathode follower is used instead of the phase splitter and negative feedback tone control is added. It's not really different from any 1 op amp 3 band eq plan that that Google can find, except it uses tubes. It can give approximately 15dB boost or cut at 50 Hz, 1 kHz and 10 kHz
It does need to be driven from fairly low source impedance (less than 2k) or there's some loss of highs. Distortion is very low even at very high output levels, assuming output load is 100k or higher.
I haven't built this but I thought it might be useful for someone who must use tubes for everything. Here's a version that can handle 600 ohm loads http://www.kolumbus.fi/~kp5188/EQ/3bandeqwcf.svg
