Here goes a high-res copy of the current schematic. Apparently the forum restricts images to 1200px 96dpi, so I post it externally by now.
My question on decoupling refers to opamp input/output DC blocking. Mostly concerned about the added mixer pot (R198, bottom left in the diagram) possibly picking up DC from U25 or U45 (bottom right)–therefore scratching. A cap might be needed between R179 and the non-inverting input of U45, or between R179 and the output of U25? Or both?
Regarding GND, could you reference me to discussions or explain me please why GND has been deemed better than VGND for this circuit? I see the Urei is grounded, but
some other applications are not. Does this mean that no rail splitter is needed at all? Kinda shocking for me since I've been working on the rail-splitter design quite a lot, but things as they are.
Just wondering if grounding it to GND wouldn't introduce more noise.
Also, more crucially, my interpretation is that using GND will reduce the headroom of the current circuit with the opamps it was intended for (AD712/TL042, +4V min. CMV). Using GND the midpoint 0dB would badly sit at 4.5V @ 9V, while using VGND I can push the midpoint to 5.5V @ 9V, therefore maintaining 3VPP at minimum battery charge (from 4V to 7V).
The purpose of the EQ is to feed an ADC (PCM1802), which is just happy with 3VPP. I'm aware that rail-to-rail opamps are better for battery use, but I couldn't get some (ie. here recommended) TLV9102/OPA1652 yet and it feels somehow good to have a more versatile circuit as a base–knowing the consequences.
