I've got some issues with my build and stepped pots…
I'm using 23 steppes rotary switches with resistor calculated with harpo's exell file
R37, 39, 41, 43, 45 are bridged
R30 is 56200 ohms
According to the exell file, my switches are going from 105K (-5 Db) to 30K1 (+5.5 Db) center position (0db) is 56K2
all my resistors are 1% and were measured before soldering
After measures, this is my results :
with all pots centred, I'm not flat…
pots centered :
Bypass :
for sub, 40Hz and 160 Hs pots, i've got something like -2 Db @105k to +2 Db @ 30K1
For 650 Hz : -1.5 Db to +2.5 DB
For 2500K : -2.5 Db to +3.5 Db
For the Air band (all frequencies): from +2.5 Db (105k min position) to +7 Db (30K1 max position)
is everything normal or did i missed something?
I'd prefer not un solder 276 resistors and solder 276 new resistors again…
Thanks for your help
EDIT : same behavior with both channels
R30 is 56200 ohms
pots centered :
Bypass :
