peterc
I'd say 2dB steps might be fine, owing to the wide Q of the bands.
I have very rarely done huge cut or boost settings on mine.
Peter
Peter
bieckmusic said:Hi frazzman, congrats.I didn't have squealing on my unit, is it on both channels? On my self-etch I reinforced some traces with solid core wire, because eq bands were cutting in and out. A few hours with the continuity checker and I figured it out. Self-etching was a blessing and a curse...
I had squealing come up on the optical desser I built, only when I cranked the threshold all the way up, some high frequency oscillation... I too wonder what causes high frequency oscillation?
bieckmusic said:You know, maybe, it could be the end of a cap on the 2500k part of the circuit. If you trace it from the pot back and check all the caps??? I read somewhere that un-grounded filter caps can cause this, ... anyway good luck, I love my nite eq! trouble shooting has been helping me understand these circuits. Also you could try and relocate the torroid or the power supply wires away from the board??
I think it's totally worth it to get all the bugs out, otherwise it just drives me nuts![]()
best,
greg
bieckmusic said:I read somewhere that un-grounded filter caps can cause this, ...
bieckmusic said:No problem, way to go, so glad it works!!
I love my eq too, I think I'm going to add a pair of these meters. More colored flashing lights!!
http://fivefishstudios.com/component/content/article/56
So you either didn't feed it with 1VAC between XLR-pins2/3 or something is wrong with your ribbon connection. Have a look at the schematic and just follow the traces to make sure you connected it correctly.Bonsaimaster said:I am getting .122V between TP4 and TP5 so something is wrong and nothing between TP2 and TP11.
Unsolder and replace the blown from probably reversed orientation or insufficient voltage rating 47uF/35V caps CPSUb1 and CPSUb2. (if CPSUb3 and CPSUb4 are fitted with same reversed orientation as CPSUb1 and CPSUb2, unsolder and replace as well.) Caps positive leg goes in the rectangular shaped solder pad. Double check for 22R resistor values of all 4 RPSUs with PSU disconnected. They might be still alife or blown from excessive current demand of reversed fitted polarized caps.shot said:On first EQ power up there was smoke from 22R resistors near the power rail connector...
...But I noticed that bypass caps CPSUb1 and CPSUb2 are starting to grow on top. Ready to explode I guess...
What is the next step I should do?
