What are the voltages at the secondaries 20v?
Okay yeah thats very similar to mine except I have 2 4700 uF caps rather than four 1000's.Should look something like this.
What is a PE pad?(as well as the PE pad
"Protective Earth" I believe from what a google unveiled. Its a blank pad next to the DC Output terminals that has continuity to the DC Ground.What is a PE pad?
Hmmm.. it almost seems like you are getting readings you should but I won't lie, I'm having a hard time understanding some of the info..."Protective Earth" I believe from what a google unveiled. Its a blank pad next to the DC Output terminals that has continuity to the DC Ground.
Yeah sorry, I'm really confused by what is seemingly an issue. This is my first time building and dealing with a PSU.Hmmm.. it almost seems like you are getting readings you should but I won't lie, I'm having a hard time understanding some of the info...
I mean, you set your meter to dc, if you put the positive lead on a negative dc point and the negative lead to a ground...ground is ground...chassis...whatever...you should read a negative dc voltage...
If you stick your positive lead on a positive dc point, and the negative lead on ground, you should get a positive dc measurement....
I've been confused by much less. Just be carefulYeah sorry, I'm really confused by what is seemingly an issue. This is my first time building and dealing with a PSU.
I'm assuming you mean DC voltage? Should have been rectified to DC before the regulators?I have good AC Voltage getting to the regulator (317/337) inputs
I probably wouldn't... Without knowing anything, I'd say something else is goofy somewhere..There’s the PE pad that’s right next to the DC terminals that is connected to the AC ground. Can I just run a wire from that to the star ground on the toroid screw?
I posted a full pic here a bit back. Let me know if you can't open/see that and I'll just repost it.Ahhh yeah that’s not cool at all :/ I should’ve done some more research on the company before going for it. Plus, they claim in the website that they’re super available to help with build questions etc.,, 4 emails later and no response.
I’m using the Psu pub that was included with the partial kit. I’ll upload a pic below. View attachment 130888
I just see tidbits of sections...I posted a full pic here a bit back. Let me know if you can't open/see that and I'll just repost it.
When troubleshooting, it's usually best to get things working as they should. Judging from other pictures I've seen, that doesn't appear to be something done the way you're describing. Just saying I wouldn't.Would connecting the AC/DC Grounds present any sort of danger?
Well thru troubleshooting the entire PSU signal flow, the only thing that stands out as wrong/not working is the fact that the AC ground did not have continuity to the AC Ground.I just see tidbits of sections...
