Isn't it moving the operation point of the VCA?
Not 99% clear I know which of the many variants you mean.
Yes, this resistor sets cell current.
The bias current must be greater than the signal current.
Plus some margin so it don't get close to clipping.
Signal current is set by resistor into the VCA and NFB resistor out of the VCA.
Because there are multiple paths inside the VCA, "bias" current may have to be set 2X or more times the actual cell current... I don't care to untangle that topology tonight.
If I read it right, you are advised to use 3K9 bias and 15K NFB around the following amp.
THAT Corp sheets suggest 5K1 and 20K.
15/3.9= 3.85
20/5.1= 3.92
The peak/bias ratio is "nearly 4" in either case. The 2% difference for the two sets of values is utterly meaningless. "4" isn't an especially magic number.
The 3K9/15K values will eat a hair more power and give a few dB less hiss, but THD will rise a bit. This is
documented in the datasheet page 6.
This was NOT worth sleepless nights. Good night.
